Zum Hauptinhalt wechseln
How to Shorten a Belt
Was du brauchst
  1. How to Shorten a Belt, Measure the Belt: Schritt 1, Bild 1 von 1
    • Put your belt on.
    • Using a ruler or measuring tape, measure how much of the belt you want to remove. Make this mark on the buckle end of the belt.
    • Place a mark where you will cut the belt to shorten it.
  2. How to Shorten a Belt: Schritt 2, Bild 1 von 2 How to Shorten a Belt: Schritt 2, Bild 2 von 2
    • Measure how much of the belt is folded over the belt. Add that length to the cut mark to leave enough material to fold over the buckle.
    • Using a screwdriver, remove all screws from the buckle end of the belt.
  3. How to Shorten a Belt: Schritt 3, Bild 1 von 1
    • Using scissors, cut on the exact spot of your new mark.
    • You can round the edges of the cut to make the belt tip look neat.
    • You can add shoe or leather polish to the cut mark to ensure it is the same color as the belt.
  4. How to Shorten a Belt, Reassembling the Belt: Schritt 4, Bild 1 von 3 How to Shorten a Belt, Reassembling the Belt: Schritt 4, Bild 2 von 3 How to Shorten a Belt, Reassembling the Belt: Schritt 4, Bild 3 von 3
    • Reinsert the screws and screw them back in place using a screwdriver.
  5. How to Shorten a Belt, Add New Buckle Holes to the Belt: Schritt 5, Bild 1 von 2 How to Shorten a Belt, Add New Buckle Holes to the Belt: Schritt 5, Bild 2 von 2
    • Place your belt on a workspace that can be nailed into.
    • Place a nail on the new spot where you'd like to add a hole.
    • Hammer the nail until it goes all the way through the belt.
    • Caution: Be careful when using a hammer.
  6. How to Shorten a Belt: Schritt 6, Bild 1 von 2 How to Shorten a Belt: Schritt 6, Bild 2 von 2
    • Try on the belt and see if it fits comfortably.
    • If not, follow this guide again to add more holes.
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
CSU Los Angeles, Team S1-G7, Harris Spring 2021 Mitglied von CSU Los Angeles, Team S1-G7, Harris Spring 2021
CSULA-HARRIS-S21S1G7
2 Mitglieder
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 34
Letzte 30 Tage: 129
Insgesamt: 3,310
