Zum Hauptinhalt wechseln
How to Shorten a Sweatshirt Using the Original Hem
Was du brauchst
  1. How to Shorten a Sweatshirt Using the Original Hem, How to Shorten a Sweatshirt Using the Original Hem: Schritt 1, Bild 1 von 1
    • Lay your crewneck on a flat surface.
  2. How to Shorten a Sweatshirt Using the Original Hem: Schritt 2, Bild 1 von 2 How to Shorten a Sweatshirt Using the Original Hem: Schritt 2, Bild 2 von 2
    • Find your new desired length and mark it with chalk.
    • Using your chalk mark, use a ruler to mark across the width of your crewneck.
  3. How to Shorten a Sweatshirt Using the Original Hem: Schritt 3, Bild 1 von 1
    • Measure one inch below your desired length and mark using chalk.
  4. How to Shorten a Sweatshirt Using the Original Hem: Schritt 4, Bild 1 von 2 How to Shorten a Sweatshirt Using the Original Hem: Schritt 4, Bild 2 von 2
    • Cut along your newly marked line.
    • Make sure to cut one layer at a time to ensure a clean cut.
  5. How to Shorten a Sweatshirt Using the Original Hem: Schritt 5, Bild 1 von 1
    • Using a ruler, mark 1/2 an inch up from the hem of your crewneck.
  6. How to Shorten a Sweatshirt Using the Original Hem: Schritt 6, Bild 1 von 1
  7. How to Shorten a Sweatshirt Using the Original Hem: Schritt 7, Bild 1 von 1
    • Flip the hem inside out and align with the cut edge of your crewneck.
    • Make sure the pieces are "good side" to "good side" by ensuring the seams are facing outward.
  8. How to Shorten a Sweatshirt Using the Original Hem: Schritt 8, Bild 1 von 1
    • Pin both pieces together with all pins facing perpendicularly to the lines you marked.
  9. How to Shorten a Sweatshirt Using the Original Hem: Schritt 9, Bild 1 von 2 How to Shorten a Sweatshirt Using the Original Hem: Schritt 9, Bild 2 von 2
    • Sew one inch away from the edge, removing the pins as you go.
    • This step can also be done by hand with thread and a needle.
  10. How to Shorten a Sweatshirt Using the Original Hem: Schritt 10, Bild 1 von 2 How to Shorten a Sweatshirt Using the Original Hem: Schritt 10, Bild 2 von 2
    • Flip the hem right side out and admire your creation!
Ziellinie
Izzy DeLaGarza
181 Reputation
1 Anleitung geschrieben
UC Davis, Team 4-8, Vidal-Chiesa Fall 2024 Mitglied von UC Davis, Team 4-8, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S4G8
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 54
Letzte 30 Tage: 196
Insgesamt: 1,014
