Einleitung
This guide is an easy way to shorten the band of a wristwatch by removing the watch links. Watch bands are manufactured longer so they can be adjusted to your wrist size. You should complete this guide on a table or sturdy work surface. I recommend to save any watch links you remove from the watch just in case you need them in the future.
Was du brauchst
Find the arrows inside the band and place the watch so the arrows are facing down.
Place a nail in the hole on the opposite side of the arrow.
Gently tap the nail into the hole with a small hammer.
Join the clock's bands and insert the pin in the same direction as the arrow until it is sealed.
6 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Never knew how easy it was until I went through this guide. Appreciate how simple you made it
