Einleitung
Use this guide to learn how to shorten and hem a shirt sleeve.
Do you have a long-sleeved shirt you want to shorten, but don’t have a sewing machine? This guide will teach you how to shorten and hem your sleeve with a catch stitch. A catch stitch is a relatively simple stitch that can hide the raw edges of a sleeve.
In addition, being able to adjust a shirt sleeve to a desired length is a useful and cost-saving skill to have. Learning how to alter a shirt sleeve can help you repurpose old or winter clothing instead of discarding them.
Before starting this guide, be aware that Step 4 includes using sewing pins that are sharp and could cause minor injuries.
Was du brauchst
Measure out the desired length of the sleeve.
Measure the shirt sleeve to make sure it is even in the front and back of the sleeve cuff.
Use sewing pins to secure the sleeve cuff in place.
In the space above the sleeve cuff, make a right-to-left stitch.
Then push the needle right-to-left into the sleeve cuff where you made the guide lines.
To end the catch stitch, push your needle into the starting stitch and make a small knot.
Make a few more knots to secure the thread.
Cut the thread with scissors.
Turn the shirt inside out again and you're done!
Eine weitere Person hat diese Anleitung absolviert.
