Zum Hauptinhalt wechseln
How to Splice Wires for Appliance Repairs
Videoanleitung
Diese Anleitung wurde von einem YouTube-Video übertragen.
Was du brauchst
      • Unplug the appliance or turn off the breaker before touching any wiring.
      • WARNING: Don’t work on energized wires, because shock, burns, or fire can result.
      • Let hot components cool, and keep wires away from sharp sheet metal edges.
      • Expose only the wiring you need, and keep track of wire colors and locations.
      Frag FixBot
      Kommentar hinzufügen
      • Use an end-to-end connector when you’re joining two wire ends into one continuous line.
      • Use a tap connector when you need to add a second wire onto an existing wire without cutting the main line.
      • Diagram: End-to-end join: wire A — [connector] — wire B.
      • Diagram: Tap join: main wire — [tap point] — branch wire.
      Frag FixBot
      • Strip the ends of two wires, insert both stripped ends into a wire nut, and twist the cap until tight.
      • Use wire nuts when you have plenty of room and the connection won’t be easily tugged or bumped.
      • Caution: Wire nuts can be too bulky for appliance cavities, and they can pop off if the splice is stressed.
      Frag FixBot
      • Insert one stripped wire end into one side of an inline butt splice, and crimp it with a crimping tool or very strong pliers.
      • Insert the other stripped wire end into the other side, and crimp it the same way.
      • Butt splices are neat and inline, but they take practice to crimp correctly.
      • Caution: A bad crimp can pull apart easily, and the damaged connector usually can’t be reused.
      Frag FixBot
      • Unscrew the connector, and separate it into its collars and the center post section.
      • Slide a collar onto the first wire, twist the exposed strands tightly, and push the wire into the center post as firmly as you can.
      • Screw the collar into the center post until snug to lock the first wire in place.
      • Repeat the process with the second wire on the other side of the connector.
      Frag FixBot
      • Pull on both wires to confirm the splice doesn’t slide out under a normal tug.
      • These connectors use screw collars, so you can make a solid inline connection without special tools.
      • Match the connector size to the wire when possible, because different collar sizes exist.
      Frag FixBot
      • Unscrew the Posi-Tap body to expose the U-channel and the pin section.
      • Set the main wire into the U-channel so the connector wraps around the wire jacket.
      • Screw the pin section down as tight as you can until it stops, so the pin pierces the wire’s insulation and contacts the conductor.
      • This style lets you tap a line without disturbing the main wire run.
      Frag FixBot
      • Remove the branch-wire collar, insert the stripped and tightly twisted branch wire into the post section, and slide the collar onto the wire.
      • Screw the collar into the post section until snug to lock the branch wire in place.
      • Repeat the same tap-and-attach process for the second conductor when you’re adding a two-wire component, such as a heater.
      • You may only need to trim back insulation, and in some cases scissors can be used to do it.
      Frag FixBot
      • Open the connector lid to expose the channel, and lay the main wire into place.
      • Snap the connector shut to hold the main wire, then insert the branch wire into either side of the connector.
      • Press the metal clip down until fully seated so it cuts into the insulation and makes the electrical connection.
      • Caution: You’ll usually need a tool like a multi-tool to press the metal clip down reliably.
      • Some versions include sealant to reduce oxidation in moist areas.
      Frag FixBot
      • Use Posi-style connectors when you want a strong splice without specialty crimp tools.
      • Use Scotchlok-style taps when you want an inline, sealed tap and you can press the clip down properly.
      • Use wire nuts when space allows, such as locations where bulk isn’t an issue.
      Frag FixBot
      • Redo any connection that pulls apart easily, and make sure the wire strands are tightly twisted and fully captured before tightening.
      • Use a correctly sized collar or connector if the wire won’t seat well or the splice won’t tighten securely.
      • Route the wiring so it won’t rub on metal, and reassemble the appliance before restoring power.
      Frag FixBot
Abschluss
A reliable splice is tight, inline when possible, and passes a firm tug test without slipping. If a splice looks bulky for the cavity or seems easy to pull apart, redo it before powering the appliance back on. Repair didn't go as planned? Ask our Answers community for help.
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 61
Letzte 30 Tage: 318
Insgesamt: 858
