Einleitung
If your Longwise ES06 electric scooter's stem/handle is shaky, follow this guide to tighten the stem so you're ready to ride again safely.
This guide focus on stabilizing the stem/handle of the scooter, restoring the full function of the electric scooter. Riding a scooter with a shaky stem can be dangerous to the rider and passersby because there's a greater chance of losing control if your scooter is loose at the stem.
Before beginning this guide, turn off the e-scooter and unplug it from the charger.
Was du brauchst
Power off your E-Scooter and make sure it is not charging.
Slide the locking clip out from the base of the stem.
Unlock the clamp on the stem.
Using an adjustable wrench, carefully tighten the bolt at the base of the stem.
Using a slotted/flathead screwdriver, carefully tighten the screw on the clamp.
