Zum Hauptinhalt wechseln
How to Stitch a Hole on the Seam of a T-Shirt
Was du brauchst
  1. How to Stitch a Hole on the Seam of a T-Shirt, How to Stitch a Hole on the Seam of a T-Shirt: Schritt 1, Bild 1 von 1
    • Turn the shirt inside out. This will ensure the new seam is sewn on the inside of the shirt.
  2. How to Stitch a Hole on the Seam of a T-Shirt: Schritt 2, Bild 1 von 3 How to Stitch a Hole on the Seam of a T-Shirt: Schritt 2, Bild 2 von 3 How to Stitch a Hole on the Seam of a T-Shirt: Schritt 2, Bild 3 von 3
    • Cut a long piece of thread and insert it into the loop of the needle .
    • Tie the loose ends of the thread into a small knot.
  3. How to Stitch a Hole on the Seam of a T-Shirt: Schritt 3, Bild 1 von 1
    • Take your thumb and first finger and pinch the sides of the hole together.
    • This will create less width for the needle to go through.
  4. How to Stitch a Hole on the Seam of a T-Shirt: Schritt 4, Bild 1 von 2 How to Stitch a Hole on the Seam of a T-Shirt: Schritt 4, Bild 2 von 2
    • Insert the needle on the edge of the hole.
    • Place the needle right below the tear of the fabric.
    • Make sure the knot of thread does not follow the needle while stitching and stays on the outside of the fabric.
  5. How to Stitch a Hole on the Seam of a T-Shirt: Schritt 5, Bild 1 von 2 How to Stitch a Hole on the Seam of a T-Shirt: Schritt 5, Bild 2 von 2
    • To secure the knot of thread, place the needle within the outside loop of thread and pull the needle through.
    • This will establish a firm base for a stitch.
  6. How to Stitch a Hole on the Seam of a T-Shirt: Schritt 6, Bild 1 von 3 How to Stitch a Hole on the Seam of a T-Shirt: Schritt 6, Bild 2 von 3 How to Stitch a Hole on the Seam of a T-Shirt: Schritt 6, Bild 3 von 3
    • With a firm pinch, start stitching the tear together by inserting the needle through both sides of the fabric, coming back to the side the needle was inserted on, and pulling tightly.
    • Make sure the thread does not get tangled, and make your stitches as close to one another as possible.
    • Continue this step until you have reached the end of the tear.
  7. How to Stitch a Hole on the Seam of a T-Shirt: Schritt 7, Bild 1 von 3 How to Stitch a Hole on the Seam of a T-Shirt: Schritt 7, Bild 2 von 3 How to Stitch a Hole on the Seam of a T-Shirt: Schritt 7, Bild 3 von 3
    • Once completed, take the needle and thread back to the first stitch.
    • Insert the needle through the first stitch until the thread has made a small loop outside of the seam.
    • Insert the needle through the small loop and pull tightly.
    • Repeat this step to secure the stitching from unraveling and cut the thread as close to the new seam as possible.
Ziellinie
Aylin Castillo
145 Reputation
1 Anleitung geschrieben
Texas Tech, Team S14-G1, Cowan Fall 2020 Mitglied von Texas Tech, Team S14-G1, Cowan Fall 2020
TTU-COWAN-F20S14G1
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 18
Letzte 30 Tage: 80
Insgesamt: 1,880
