Einleitung
The fader arm is made of an easily bendable metal. Because of this, small bumps or a push in the wrong direction can accidentally bend the arm. This guide will show you how to bend the arm back to its proper alignment.
Was du brauchst
Remove the fader cap from the bent fader arm
Use needle nose pliers to hold the fader arm in position.
Gently straighten the fader arm.
Eine weitere Person hat diese Anleitung absolviert.
