Einleitung
Cast iron is a porous metal that easily forms rust, making it unsafe for cooking. It is a great piece of cookware that can last with proper care. Use this guide to restore your cast iron skillet by stripping and replacing the coating.
This guide requires the use of power tools, so it is strongly recommended to wear safety equipment when handling any of these tools. Grinders are especially dangerous without eye protection.
Before beginning, make sure you are in a well ventilated area. Metal dust will quickly fill the air around you.
Was du brauchst
Clamp down opposite sides of the cast iron skillet to a table.
Grind off the black coating of the entire surface to expose the shiny bare metal.
Sand the entire surface of the cast iron skillet to smooth any rough spots left.
Rinse the cast iron skillet with water.
Scrub the cast iron skillet with a sponge to remove any excess metal shavings.
Apply an even coating of high heat oil to every part of your cast iron skillet.
Wrap the bottom rack of the oven with aluminum foil.
Place the cast iron skillet upside down on the rack above the foil.
Bake for 1 hour in a preheated oven of 500°F (260°C) or whatever the highest temperature your oven reaches.
Let the cast iron skillet cool completely after baking.
The finished product will be a dark black that resembles a non-stick coating and has no sticky patches.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
