Zum Hauptinhalt wechseln
How to Strip and Recoat a Cast Iron Skillet
Was du brauchst
  1. How to Strip and Recoat a Cast Iron Skillet, How to Replace a Cast Iron Skillet Coating: Schritt 1, Bild 1 von 3 How to Strip and Recoat a Cast Iron Skillet, How to Replace a Cast Iron Skillet Coating: Schritt 1, Bild 2 von 3 How to Strip and Recoat a Cast Iron Skillet, How to Replace a Cast Iron Skillet Coating: Schritt 1, Bild 3 von 3
    • Clamp down opposite sides of the cast iron skillet to a table.
    • Make sure the clamps are secure to avoid injury.
    Frag FixBot
    Kommentar hinzufügen
  2. How to Strip and Recoat a Cast Iron Skillet: Schritt 2, Bild 1 von 3 How to Strip and Recoat a Cast Iron Skillet: Schritt 2, Bild 2 von 3 How to Strip and Recoat a Cast Iron Skillet: Schritt 2, Bild 3 von 3
    • Grind off the black coating of the entire surface to expose the shiny bare metal.
    • Make sure to have on all your safety equipment for this process.
    Frag FixBot
  3. How to Strip and Recoat a Cast Iron Skillet: Schritt 3, Bild 1 von 3 How to Strip and Recoat a Cast Iron Skillet: Schritt 3, Bild 2 von 3 How to Strip and Recoat a Cast Iron Skillet: Schritt 3, Bild 3 von 3
    • Sand the entire surface of the cast iron skillet to smooth any rough spots left.
    Frag FixBot
  4. How to Strip and Recoat a Cast Iron Skillet: Schritt 4, Bild 1 von 2 How to Strip and Recoat a Cast Iron Skillet: Schritt 4, Bild 2 von 2
    • Rinse the cast iron skillet with water.
    • Scrub the cast iron skillet with a sponge to remove any excess metal shavings.
    Frag FixBot
  5. How to Strip and Recoat a Cast Iron Skillet: Schritt 5, Bild 1 von 2 How to Strip and Recoat a Cast Iron Skillet: Schritt 5, Bild 2 von 2
    • Apply an even coating of high heat oil to every part of your cast iron skillet.
    Frag FixBot
  6. How to Strip and Recoat a Cast Iron Skillet: Schritt 6, Bild 1 von 2 How to Strip and Recoat a Cast Iron Skillet: Schritt 6, Bild 2 von 2
    • Wrap the bottom rack of the oven with aluminum foil.
    • Place the cast iron skillet upside down on the rack above the foil.
    • Bake for 1 hour in a preheated oven of 500°F (260°C) or whatever the highest temperature your oven reaches.
    • Let the cast iron skillet cool completely after baking.
    Frag FixBot
  7. How to Strip and Recoat a Cast Iron Skillet: Schritt 7, Bild 1 von 3 How to Strip and Recoat a Cast Iron Skillet: Schritt 7, Bild 2 von 3 How to Strip and Recoat a Cast Iron Skillet: Schritt 7, Bild 3 von 3
    • Repeat steps 5 and 6 until a dark black coating has formed.
    Frag FixBot
Abschluss
The finished product will be a dark black that resembles a non-stick coating and has no sticky patches.
4 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
Thanks so much for posting this🍳
Mrs. Schneider - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 18
Letzte 30 Tage: 103
Insgesamt: 4,857
