Zum Hauptinhalt wechseln
How to Tailor Your Pants
Was du brauchst
    1. How to Tailor Your Pants, How to Tailor Your Pants: Schritt 1, Bild 1 von 1
      • To make the process of tailoring your pants easier, use a second pair of pants that already has the desired length as an outline.
      • Place the pants with the length you want on top of the pants that you will be tailoring.
      Frag FixBot
      Kommentar hinzufügen
    2. How to Tailor Your Pants: Schritt 2, Bild 1 von 1
      • Measure the length you want to cut off with your fingers.
      • The amount of fingers you use may vary depending on the length you want to cut off.
      Frag FixBot
    3. How to Tailor Your Pants: Schritt 3, Bild 1 von 1
      • Pin your pants at the length you want to cut off.
      • An alternative option to pinning your pants is marking the length with a pencil.
      Frag FixBot
    4. How to Tailor Your Pants: Schritt 4, Bild 1 von 1
      • Cut along the pins.
      • Cut along the pencil mark if you chose this option instead.
      Frag FixBot
    5. How to Tailor Your Pants: Schritt 5, Bild 1 von 1
      • Fold the pants so that the seam is on the inside. Next, sew along the folded edge with a sewing machine.
      • Pin the pants to keep the fold in place and to make sewing easier.
      Frag FixBot
    6. How to Tailor Your Pants: Schritt 6, Bild 1 von 1
      • Check to make sure your pants are now your desired length.
      Frag FixBot
    7. How to Tailor Your Pants: Schritt 7, Bild 1 von 1
      • If you have achieved your desired length then you are finished!
      Frag FixBot
Abschluss
You finally finished sewing your jeans so now you can enjoy wearing them :)
Exlexis Archouletta
133 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team S12-G14, Harris Fall 2020 Mitglied von CSU Los Angeles, Team S12-G14, Harris Fall 2020
CSULA-HARRIS-F20S12G14
1 Mitglied
11 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 32
Insgesamt: 1,141
