Set the gas supply to 5 L/min.
Completely close the Peak Inspiratory Pressure control and the Max Pressure control by turning both knobs completely clockwise.
Close the bleed valve and turn the Max Pressure Relief valve until the manometer reads 40 cmh2O.
Reset the peak inspiratory pressure to 20 cmh2O and turn off the gas flow. Testing is now complete. If the F&P Neopuff/Perivent Infant Resuscitator fails any of these tests, the valve assembly should be regarded as faulty and replaced with a new valve assembly (see the parts list (section 4.1.2) for part numbers).
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
