Zum Hauptinhalt wechseln
How to Tie a Tie: Prince Albert
Was du brauchst
  1. How to Tie a Tie: Prince Albert, Preparation: Schritt 1, Bild 1 von 1
    • Fold the collar of your shirt up.
  2. How to Tie a Tie: Prince Albert: Schritt 2, Bild 1 von 1
    • Wrap the tie around the back of your neck with the narrow end on the left side of your body and the wide end on the right side.
    • The wide end of the tie will be your active end.
    • Note: the narrow end of the tie should be around the height of your belly button or a little higher. It may need to adjusted for personal height.
  3. How to Tie a Tie: Prince Albert, Tying: Schritt 3, Bild 1 von 1
    • Take the active end and cross it over the narrow end, so that it points to the left.
    • Note: be sure that the tie always lays flat so there are no twists in the fabric.
  4. How to Tie a Tie: Prince Albert: Schritt 4, Bild 1 von 1
    • Wrap active end under the narrow end, so that it now points to the right.
    • Note: leave this wrap, and subsequent wraps, a little loose.
  5. How to Tie a Tie: Prince Albert: Schritt 5, Bild 1 von 1
    • Wrap the active end over the narrow end, so that it now points to the left.
    • Note: Leave this wrap a little loose as it will be used in step 9.
  6. How to Tie a Tie: Prince Albert: Schritt 6, Bild 1 von 1
    • Wrap the active end under the narrow end, so that it now points to the right.
  7. How to Tie a Tie: Prince Albert: Schritt 7, Bild 1 von 1
    • Note: Leave this wrap a little loose, as it will be used in step 9.
  8. How to Tie a Tie: Prince Albert: Schritt 8, Bild 1 von 1
    • Pull the active end up through the neck loop, so that it now points up.
  9. How to Tie a Tie: Prince Albert: Schritt 9, Bild 1 von 3 How to Tie a Tie: Prince Albert: Schritt 9, Bild 2 von 3 How to Tie a Tie: Prince Albert: Schritt 9, Bild 3 von 3
    • Pull the active end down through the wraps you created in steps 5 (see image 2) and 7 (see image 3).
  10. How to Tie a Tie: Prince Albert, Finishing: Schritt 10, Bild 1 von 1
    • Tighten the knot by pulling down on the active end and up on the knot, adjusting for size and evenness.
  11. How to Tie a Tie: Prince Albert: Schritt 11, Bild 1 von 1
    • Tighten the neck loop by pulling down on the narrow end of the tie and sliding the knot up toward your neck.
  12. How to Tie a Tie: Prince Albert: Schritt 12, Bild 1 von 1
    • Tuck the narrow end of the tie through the keeper loop.
    • Note: if the narrow end is too long, a simple solution lies in tucking the narrow end between two buttons of your shirt.
    • Fold your collar down when the knot is finished.
Abschluss
Congratulations! You've successfully tied the Prince Albert knot!
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Wes
514 Reputation
2 Anleitungen geschrieben
The Electric Warthogs Mitglied von The Electric Warthogs
Community
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 409
