Zum Hauptinhalt wechseln
How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model
Was du brauchst
  1. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model, How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: Schritt 1, Bild 1 von 3 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model, How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: Schritt 1, Bild 2 von 3 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model, How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: Schritt 1, Bild 3 von 3
    • Unlock the brake barrel adjusters fasteners with a flathead screwdriver in the clockwise direction.
    • Loosening the fasteners will help to loosen the barrel in Step 2.
  2. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: Schritt 2, Bild 1 von 3 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: Schritt 2, Bild 2 von 3 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: Schritt 2, Bild 3 von 3
    • Twist in the clockwise direction to tighten the barrel adjusters.
  3. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: Schritt 3, Bild 1 von 2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: Schritt 3, Bild 2 von 2
    • While squeezing the bike brake check the distance between the brake handle and the bike handle using a measuring device.
    • It should be about an inch if properly tightened.
    • The second image has a loose brake. The distance is less than an inch, where it should be more than an inch (reference step 8 for the right distance). This indicates that the brake is still loose.
  4. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: Schritt 4, Bild 1 von 2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: Schritt 4, Bild 2 von 2
    • Prepare for the next few steps by loosening the bike brake barrel adjuster if it is fully tightened by turning it clockwise a few times.
    • Start by squeezing the brake arms together as much as possible.
  5. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: Schritt 5, Bild 1 von 1
    • While maintaining the position of the brake arms from Step 4, loosen the bolt that secures the cable clamp using a 5mm Allen Wrench and turn it counter clockwise.
    • Loosen the bolt until the cable can be adjusted easily by hand.
  6. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: Schritt 6, Bild 1 von 2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: Schritt 6, Bild 2 von 2
    • While keeping the bike brake arms in the same position as described in Step 5, pull the brake cable to adjust the distance between the brake pads and the wheel.
    • Stop pulling when the brake pads are one or two millimeters away from the wheel.
  7. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: Schritt 7, Bild 1 von 2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: Schritt 7, Bild 2 von 2
    • With the brake arms still squeezed together, use the 5 mm Allen wrench to tighten the cable clamp by turning the wrench in a clockwise direction.
  8. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: Schritt 8, Bild 1 von 2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: Schritt 8, Bild 2 von 2
    • Tighten the brake barrel adjusters again (as seen in step 2). Do this until the brake handle reaches 25.4 mm from the handle when squeezing.
    • When tightening the brakes, ensure that the brake pads never touch the side of the wheel. If this occurs, then the brake cable was pulled too tight in Step 6 and needs to be loosened.
  9. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: Schritt 9, Bild 1 von 2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: Schritt 9, Bild 2 von 2
    • Finally, use the flathead screwdriver to lock the barrel adjuster fastener. Use the screwdriver to twist the fastener in a counterclockwise direction until it is tight.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Emily Arana
169 Reputation
1 Anleitung geschrieben
UCD-MORRIS-S23S1G1 Mitglied von UCD-MORRIS-S23S1G1
Community
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 5
Letzte 30 Tage: 18
Insgesamt: 168
