Zum Hauptinhalt wechseln
How to Troubleshoot a GE Top Load Washing Machine Not Starting
Was du brauchst
    • Ensure the dial is not stripped or cracked by rotating it and listening for a click.
    • Confirm that pressing the start button produces a click sound from the control board.
    • Examine the lid for any bulging or warping near the striker area.
    • Make sure the striker aligns correctly with the lid lock when the lid closes.
    • Check if the striker is seated flat against the lid and not bent or broken.
    • Look for clogged mesh filters in the water inlet valves at the back of the machine.
    • Verify that both hot and cold water supply hoses are providing adequate flow.
    • Remove any debris blocking the valves to ensure proper water supply.
    • Tilt the washer back carefully and look underneath or on the sides for a plastic pouch.
    • Retrieve the technician’s mini-manual for diagnostic codes and wiring schematics.
    • Use an online reference if you cannot find the original tech sheet.
    • Press and hold the start button for ten seconds, then release it to view error codes.
    • Observe which lights blink alongside pause and lid lock indicators to identify errors.
    • Press the start button repeatedly to cycle through stored codes.
    • Compare the light patterns to the tech sheet or an online resource for exact meaning.
    • Rotate the dial to exit error code mode after viewing the codes.
    • Press and hold the start button while turning the selector dial seven increments, then release it.
    • Listen for a click and flashing lights to confirm entry into the field service mode.
    • Turn the dial counterclockwise four clicks until only the sensing fill light is on.
    • Press and hold the start button for three seconds to delete stored error codes.
    • Re-run the machine to capture active codes only, aiding in accurate troubleshooting.
    • Rotate the dial past the error code deletion step to select agitate, spin, or lid lock tests.
    • Use these forced operations to confirm which component fails to function properly.
    • If a mode does not activate, the related part is likely defective.
    • Unplug the washing machine to avoid electrical hazards.
    • Move the unit away from the wall to access the rear panel.
    • Remove two quarter-inch screws from each side of the top’s rear panel.
    • Slide the back metal housing to the right and pull it away to expose the control board.
    • Detach any cardboard or plastic flaps to access the board and the pressure hose.
    • Unplug the pressure hose from the board if you need to fully remove the console.
    • Remove two long screws on each rear corner to free the lid assembly from the chassis.
    • Snap the console forward and press down on two hidden front clips with a putty knife.
    • Lift the top upward to reveal the lid lock and its wiring harness.
    • Unplug the wiring harness from the lid lock if it is still connected.
    • Release the white plastic bezel by pressing the outside tabs and pushing it out.
    • Use a small screwdriver to press the lock’s top tab and slide the assembly left for removal.
    • Replace the striker if damaged by removing its two mounting screws on the lid.
    • Align any replacement striker so it fits into the same orientation as the old one.
    • Select a matching GE lid lock assembly if needed and ensure it aligns with the bezel.
    • Slide the new lid lock into the opening and secure it with a left-to-right motion.
    • Press the bezel back into place, aligning the guiding peg correctly.
    • Reconnect the lid lock wiring harness and make sure it is fully seated.
    • Close the top panel and press down on the front edge to engage the hidden clips.
    • Reinstall the capacitor, screws, and the back metal plate at the control area.
    • Verify the capacitor wires match their original orientation before closing.
    • Tilt or lay the washing machine on its back, ensuring the drain hose stays above the tub.
    • Support the machine so the lid does not slam open or shut unexpectedly.
    • Remove three 3 8 inch screws from the plastic bottom cover and note the grounding strap.
    • Check the plastic cover for oil stains, belt debris, or broken tabs.
    • Rotate the pulleys by hand and pull the belt away to slip it off both pulleys.
    • Examine the belt for fraying, grease, or any other visible damage.
    • Clean or replace the belt if it shows signs of slipping or excessive wear.
    • Use a 9 16 or 15 mm socket wrench to loosen the pulley nut counterclockwise.
    • Pry the pulley off gently with a large screwdriver or a specialized puller tool.
    • Inspect the speed sensor for any belt debris or damage and unplug it if needed.
    • Remove the sensor by pressing the side tabs and sliding it off the motor housing.
    • Reconnect the sensor by aligning tabs, plugging the harness, and securing the red lock tab.
    • Loosen the pulley nut with a socket wrench and tap or pull the pulley off the shaft.
    • Unplug the shifter harness and remove two 3 8 inch screws holding it in place.
    • Support the assembly so the loaded spring does not pop out when the final screw is removed.
    • Check the clutch spring, plastic housing, and shifter assembly for damage or wear.
    • Verify the coil resistance with a multimeter according to the machine’s schematic.
    • Replace any defective parts and reassemble the shifter, spring, and clutch in reverse order.
    • Align the belt on the motor pulley and begin slipping it onto the transmission pulley.
    • Rotate the transmission pulley to help the belt slide fully into place.
    • Reattach the plastic bottom cover using three screws, including the grounding strap.
    • Set the washer upright and reconnect the power supply to confirm operation.
Abschluss
These procedures address the most common causes of a GE washer failing to start, including faulty controls, lid locks, or drive system issues. If you continue to experience problems, consult a more detailed service manual or seek professional assistance to prevent further damage.
Eine weitere Person hat diese Anleitung absolviert.
Ben Schlichter
2.183 Reputation
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 31
Letzte 30 Tage: 142
Insgesamt: 1,289
