Zum Hauptinhalt wechseln
How to True a Bicycle Wheel with Zip Ties
Was du brauchst
  1. How to True a Bicycle Wheel with Zip Ties, How to True a Bicycle Wheel with Zip Ties: Schritt 1, Bild 1 von 1
    • Place your bike upside down.
  2. How to True a Bicycle Wheel with Zip Ties: Schritt 2, Bild 1 von 1
    • Tie a zip tie next to the rim of your wheel.
  3. How to True a Bicycle Wheel with Zip Ties: Schritt 3, Bild 1 von 2 How to True a Bicycle Wheel with Zip Ties: Schritt 3, Bild 2 von 2
    • Cut the zip tie.
    • The zip tie should barely touch the rim.
  4. How to True a Bicycle Wheel with Zip Ties: Schritt 4, Bild 1 von 1
    • Spin the wheel and mark the spots where the rim touches the zip tie.
  5. How to True a Bicycle Wheel with Zip Ties: Schritt 5, Bild 1 von 2 How to True a Bicycle Wheel with Zip Ties: Schritt 5, Bild 2 von 2
    • Slowly loosen the spoke that is on the side of the zip tie.
    • Slowly tighten the spoke that is away from the zip tie.
    • Turn clockwise to tighten and counterclockwise to loosen.
  6. How to True a Bicycle Wheel with Zip Ties: Schritt 6, Bild 1 von 1
    • Repeat steps 2 to 5 with the zip tie on the other side of the wheel.
Abschluss
Repeat the instructions on your other wheel.
Niyoosha Tahami
133 Reputation
1 Anleitung geschrieben
York University, Team 1-28, O'Regan Summer 2024 Mitglied von York University, Team 1-28, O'Regan Summer 2024
YORK-O'REGAN-SU24S1G28
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 28
Insgesamt: 173
