Zum Hauptinhalt wechseln
How to Unclog Epson Workforce 2760 Ink Heads
Was du brauchst
  1. How to Unclog Epson Workforce 2760 Ink Heads, How to Unclog Epson Workforce 2760 Ink Heads: Schritt 1, Bild 1 von 3 How to Unclog Epson Workforce 2760 Ink Heads, How to Unclog Epson Workforce 2760 Ink Heads: Schritt 1, Bild 2 von 3 How to Unclog Epson Workforce 2760 Ink Heads, How to Unclog Epson Workforce 2760 Ink Heads: Schritt 1, Bild 3 von 3
    • In the "Settings" menu, set the printer cartridges to "Replace ink cartridges."
  2. How to Unclog Epson Workforce 2760 Ink Heads: Schritt 2, Bild 1 von 3 How to Unclog Epson Workforce 2760 Ink Heads: Schritt 2, Bild 2 von 3 How to Unclog Epson Workforce 2760 Ink Heads: Schritt 2, Bild 3 von 3
    • Move the cartridge to the side.
    • Place a towel underneath.
  3. How to Unclog Epson Workforce 2760 Ink Heads: Schritt 3, Bild 1 von 2 How to Unclog Epson Workforce 2760 Ink Heads: Schritt 3, Bild 2 von 2
    • Place the cleaning solution of 100 mL in a cup of hot boiling water, with the cap off to avoid air pressure that can damage the solution.
  4. How to Unclog Epson Workforce 2760 Ink Heads: Schritt 4, Bild 1 von 3 How to Unclog Epson Workforce 2760 Ink Heads: Schritt 4, Bild 2 von 3 How to Unclog Epson Workforce 2760 Ink Heads: Schritt 4, Bild 3 von 3
    • Pull 5 mL of the hot solution using the syringe.
    • Apply the solution to the black printer head first.
    • After applying the solution, wait one hour for the solution to break down the dried ink.
  5. How to Unclog Epson Workforce 2760 Ink Heads: Schritt 5, Bild 1 von 3 How to Unclog Epson Workforce 2760 Ink Heads: Schritt 5, Bild 2 von 3 How to Unclog Epson Workforce 2760 Ink Heads: Schritt 5, Bild 3 von 3
    • After one hour, repeat steps one through four on the other ink heads.
    • Move the ink slot back into place, and insert the new ink cartridges.
    • Under "Settings," finish replacing ink cartridges process.
    • Print a "test page" and if the results shown on image three appear, the printer heads are successfully unclogged.
Ziellinie
CSU Los Angeles, Team 1-1, Briggs Fall 2023 Mitglied von CSU Los Angeles, Team 1-1, Briggs Fall 2023
CSULA-BRIGGS-F23S1G1
6 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 97
