Einleitung
You may think your Keurig is broken and done for good, but it may just be clogged. Use this guide to unclog your Keurig coffee brewer in just a few easy steps. All you'll need is your coffee brewer, a paperclip, a bottle of white vinegar and approximately 30 minutes.
Was du brauchst
Disassemble all of the parts. This includes: water tank, lid, K-cup holder, and both pieces of the tray where the coffee cup sits.
Wash all of the parts in warm, soapy water. Dry well.
Unclog the needles using a slightly bent paperclip.
With the top of the Keuring open, insert the free end of the paperclip into the three small holes surrounding the needle that pierces the K-Cup.
Jiggle the paperclip to loosen any debris.
Wipe the whole machine down and reassemble all of the previously removed parts.
Fill the water tank with a half water-half vinegar solution.
Run the water-vinegar solution through the machine until you have emptied the tank.
Run clean water through the machine. You may have to repeat this step several times to get all of the water-vinegar solution out of the pipes.
Repeat this process every 2-3 months for optimal use of your Keurig, and to increase the lifespan of your coffee brewer.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
