Einleitung
Using your Keurig K-Classic very frequently may start to cause build up of coffee grounds in the dispensing area. This causes you to get less out of your Keurig and a less amount of coffee to take on your daily activities.
These 8 steps can help you revive your Keurig K-Classic, with low budget materials which means less coming out of your pocket. Before starting, make sure you have set aside an hour to complete the task. This is including the wait time of 45 minutes for your Keurig to stay at rest.
Before starting this procedure, make sure you are able to easily connect and disconnect your Keurig to a power source as well as be near a sink for disposal.
Was du brauchst
Unplug the Keurig and take off the water reservoir.
Fill the water reservoir about halfway with white vinegar, then fill the rest of the water reservoir with water.
Remove the water reservoir and rinse out with fresh water to remove any leftover vinegar.
Place the water filter back in the water reservoir.
Place the lid back on top of the water reservoir, and insert entire part back on the Keurig.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
