Zum Hauptinhalt wechseln
How to Unclog a Shark Rocket Deluxe Pro Vacuum
Was du brauchst
  1. How to Unclog a Shark Rocket Deluxe Pro Vacuum, How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 1, Bild 1 von 2 How to Unclog a Shark Rocket Deluxe Pro Vacuum, How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 1, Bild 2 von 2
    • Press the wand release button to remove the vacuum body from the roller brush and wand.
  2. How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 2, Bild 1 von 2 How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 2, Bild 2 von 2
    • Press the button at the bottom of the power cord on the dust bin.
    • Pull off the attached piece.
    • Remove the small filter from the piece.
  3. How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 3, Bild 1 von 2 How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 3, Bild 2 von 2
    • Pull the lever on top of the dust bin to expose the main filters.
  4. How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 4, Bild 1 von 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 4, Bild 2 von 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 4, Bild 3 von 3
    • Carefully squeeze and remove the top filter.
    • Underneath that filter is a second filter. Pull the tab to remove it.
  5. How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 5, Bild 1 von 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 5, Bild 2 von 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 5, Bild 3 von 3
    • Squeeze the release on the bottom of the dustbin.
    • Remove the dust bin from the base.
    • Pop the lid open using the slider.
    • Empty the dust bin into the trash.
  6. How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 6, Bild 1 von 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 6, Bild 2 von 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 6, Bild 3 von 3
    • Rinse and wipe the plastic pieces removed earlier.
    • Do not use soap.
    • Set the pieces aside to air-dry.
  7. How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 7, Bild 1 von 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 7, Bild 2 von 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 7, Bild 3 von 3
    • Place the filters in your sink and rinse out the dirt.
    • Squeeze out any excess water and allow them to air-dry overnight before reinstalling.
    • DO NOT USE SOAP.
  8. How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 8, Bild 1 von 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 8, Bild 2 von 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 8, Bild 3 von 3
    • With a wet rag wipe out any dirt buildup on the vacuum casing.
  9. How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 9, Bild 1 von 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 9, Bild 2 von 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 9, Bild 3 von 3
    • Turn the base of the vacuum on its side.
    • With your scissors, cut any wrapped hairs or strings that may be stuck on the rollers.
  10. How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 10, Bild 1 von 2 How to Unclog a Shark Rocket Deluxe Pro Vacuum: Schritt 10, Bild 2 von 2
    • Lastly, insert your drain snake into the tube of the vacuum to dislodge any large stuck items.
Abschluss
Savannah Webb
181 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 23
Letzte 30 Tage: 68
Insgesamt: 1,995
