Zum Hauptinhalt wechseln
How to Unclog a Shower Drain
Was du brauchst
  1. How to Unclog a Shower Drain, How to Unclog a Shower Drain: Schritt 1, Bild 1 von 1
    • Gloves are optional should you desire them. They may help to keep yourself as clean as possible.
  2. How to Unclog a Shower Drain: Schritt 2, Bild 1 von 3 How to Unclog a Shower Drain: Schritt 2, Bild 2 von 3 How to Unclog a Shower Drain: Schritt 2, Bild 3 von 3
    • Remove the drain snake from it's packaging. Be sure to straighten out your drain snake as much as possible for ease of use.
    • Make sure that its edges are firm, or else it will not be able to snag the material easily.
  3. How to Unclog a Shower Drain: Schritt 3, Bild 1 von 1
    • Unscrew the drain. This step is also optional, but it will be easier to help utilize the drain snake to its max potential.
    • After removing the handle, use a screwdriver to remove the rest of the drain.
  4. How to Unclog a Shower Drain: Schritt 4, Bild 1 von 3 How to Unclog a Shower Drain: Schritt 4, Bild 2 von 3 How to Unclog a Shower Drain: Schritt 4, Bild 3 von 3
    • Make sure drain is not closed throughout this step.
    • Stick your drain snake as deep into the drain gateway as you can. The further down you go, the greater the results. May also vary depending on status of drain.
  5. How to Unclog a Shower Drain: Schritt 5, Bild 1 von 2 How to Unclog a Shower Drain: Schritt 5, Bild 2 von 2
    • Spin and turn the drain snake around to gather as much material as you can.
    • After removing drain snake, extract all material from the snake and dispose of it in the garbage. Repeat this step until you have reached satisfactory results.
  6. How to Unclog a Shower Drain: Schritt 6, Bild 1 von 3 How to Unclog a Shower Drain: Schritt 6, Bild 2 von 3 How to Unclog a Shower Drain: Schritt 6, Bild 3 von 3
    • Take out your pump and a container full of warm water.
    • Extract water from your container and exert pressure into the drain to clean it out.
    • Repeat step a few times, and then test the status of your drain by starting up your bath tub and seeing if water flows naturally down the drain.
    • If everything goes as planned, your bath tub drain should be of good use again!
Abschluss
Preston Aguada
133 Reputation
1 Anleitung geschrieben
UW Tacoma, Team S1-G1, Cardinal Summer 2020 Mitglied von UW Tacoma, Team S1-G1, Cardinal Summer 2020
UWT-CARDINAL-SU20S1G1
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 16
Insgesamt: 326
