Einleitung
Both kitchen and bathroom drains get used often and clogged fast. But did you know that it’s possible to clear a clogged sink without using harsh chemicals? Just a few everyday household items and hot water work just as well as chemicals. Taking precautions to prevent burning hands and arms from boiling water and the stovetop is essential, so use potholders and work slowly and carefully. The prep time to create the mix of baking soda and vinegar is fast and easy to clean up. If vinegar isn’t available, lemon juice is a great substitute.
Was du brauchst
Measure two cups of tap water.
Pour the tap water into a tea kettle and heat the water until it boils.
Slowly pour boiling water down the clogged drain.
Measure one cup of vinegar.
Pour vinegar into the bowl with the baking soda.
Use a spatula to mix the contents until they form a paste.
Measure two additional cups of tap water.
Allow the water to drain completely.
Run the tap for approximately 5 - 10 minutes.
