Zum Hauptinhalt wechseln
How to Unclog a Sink without Harsh Chemicals
Was du brauchst
  1. How to Unclog a Sink without Harsh Chemicals, How to Unclog a Sink without Harsh Chemicals: Schritt 1, Bild 1 von 1
    • Measure two cups of tap water.
    • Pour the tap water into a tea kettle and heat the water until it boils.
    • Boiling water may cause burns. Handle with care. Turn stove off after use.
    • Slowly pour boiling water down the clogged drain.
    • This is to avoid splash back and possible injury.
  2. How to Unclog a Sink without Harsh Chemicals: Schritt 2, Bild 1 von 2 How to Unclog a Sink without Harsh Chemicals: Schritt 2, Bild 2 von 2
    • Measure one cup of baking soda.
    • Pour baking soda into a large mixing bowl.
  3. How to Unclog a Sink without Harsh Chemicals: Schritt 3, Bild 1 von 3 How to Unclog a Sink without Harsh Chemicals: Schritt 3, Bild 2 von 3 How to Unclog a Sink without Harsh Chemicals: Schritt 3, Bild 3 von 3
    • Measure one cup of vinegar.
    • Pour vinegar into the bowl with the baking soda.
    • Alternatively, mix in one cup of lemon juice as a substitution for the vinegar.
    • Do not use both vinegar and lemon juice.
    • Use a spatula to mix the contents until they form a paste.
  4. How to Unclog a Sink without Harsh Chemicals: Schritt 4, Bild 1 von 1
    • Pour the combination down the drain using a spatula.
  5. How to Unclog a Sink without Harsh Chemicals: Schritt 5, Bild 1 von 1
    • Measure two additional cups of tap water.
    • Allow the water to drain completely.
    • Run the tap for approximately 5 - 10 minutes.
    • It might take more than one attempt to clear the clog. Repeat this procedure as needed.
Ziellinie
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 52
Insgesamt: 1,287
