Einleitung
Do you have a clogged sink? Do you not know what is wrong with it? Use this guide to solve your problem. If your sink becomes unclogged after step 1 or step 6, then you do not need to continue following the guide. But it is highly recommended that you finish the guide completely to ensure your sink is completely unclogged.
Was du brauchst
Begin by filling the sink halfway full with water.
Pump the plunger rapidly for 30 seconds.
Repeat this process 4 to 6 times.
Carefully untwist slip nuts by hand.
The nuts at the ends of the P-trap are called slip nuts.
Pour 1/2 cup of baking soda down the drain.
Pour 1/2 cup of distilled white vinegar down the drain.
Quickly cover the drain with a drain stopper.
As soon as the fizzing stops, pour another 1/2 cup of white distilled vinegar down the drain.
Cover again with a drain stopper.
Let the sink sit for 20 min.
Boil 1 gallon of water with a boiler.
Pour the boiling water down the sink to flush out any remaining debris.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
