Zum Hauptinhalt wechseln
How to Unclog a Toilet Without a Plunger
Was du brauchst
    1. How to Unclog a Toilet Without a Plunger, How to Unclog a Toilet Without a Plunger: Schritt 1, Bild 1 von 2 How to Unclog a Toilet Without a Plunger, How to Unclog a Toilet Without a Plunger: Schritt 1, Bild 2 von 2
      • If the toilet bowl is full of water, empty the water manually with a small or medium container so that there is enough space to add a gallon of liquid.
      • It's recommended to wear gloves (plastic or silicon gloves) for this part.
      Frag FixBot
      Kommentar hinzufügen
    2. How to Unclog a Toilet Without a Plunger: Schritt 2, Bild 1 von 2 How to Unclog a Toilet Without a Plunger: Schritt 2, Bild 2 von 2
      • Prepare a gallon of hot (not boiling) water.
      • The water temperature shouldn’t be too hot because it may cause the toilet bowl to crack.
      Frag FixBot
    3. How to Unclog a Toilet Without a Plunger: Schritt 3, Bild 1 von 2 How to Unclog a Toilet Without a Plunger: Schritt 3, Bild 2 von 2
      • Divide the gallon of water into three separate containers.
      • Pour one portion of hot water into the toilet bowl and let it rest for about 20 minutes. Repeat for the other two portions of hot water.
      Frag FixBot
    4. How to Unclog a Toilet Without a Plunger: Schritt 4, Bild 1 von 2 How to Unclog a Toilet Without a Plunger: Schritt 4, Bild 2 von 2
      • Fill the blocked part of the bowl with no more than half a cup of dish soap.
      • Let the soap sit in the toilet bowl for a few minutes.
      • The soap's grease-cutting properties could ease in removing any solids that may have created the clog.
      Frag FixBot
    5. How to Unclog a Toilet Without a Plunger: Schritt 5, Bild 1 von 1
      • Check the toilet bowl to see if the water level has decreased or remained the same.
      • If the water level decreased, flush the toilet. If it starts to overflow again, turn off the water valve from behind the toilet, and repeat Steps 1–3.
      Frag FixBot
Ziellinie
zahra azad
121 Reputation
1 Anleitung geschrieben
York University, Team 2-4, O'Regan Fall 2021 Mitglied von York University, Team 2-4, O'Regan Fall 2021
YORK-O'REGAN-F21S2G4
1 Mitglied
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 40
Letzte 30 Tage: 100
Insgesamt: 922
