Einleitung
In the event a plunger or a liquid solution fails to unclog a toilet, a $20 toilet auger can help you avoid a $150-plus plumber visit. A toilet auger, also known as a plumber's snake, is a specialized tool designed to navigate through the twists and turns of a toilet's plumbing system to dislodge and remove obstructions. Toilet augers are also used by professional plumbers. In this comprehensive guide, we will walk you through the step-by-step process of using a toilet auger to effectively and safely unclog a toilet.
Was du brauchst
Turn the auger's handle counterclockwise and pull it towards you to retract the snake.
Turn the handle clockwise to push the auger down the drain.
Stop when the handle gets stiff.
Turn the handle counterclockwise while pulling it towards you to retract the auger.
Remove the auger from the toilet and dispose of anything caught by the metal.
Eine weitere Person hat diese Anleitung absolviert.
