Zum Hauptinhalt wechseln
How to Unclog a Toilet
Was du brauchst
  1. How to Unclog a Toilet, How to Unclog a Toilet: Schritt 1, Bild 1 von 1
    • Before you begin, make sure to use the correct type of plunger:
    • A proper toilet plunger has a funnel-shaped flange extending from the bottom of the rubber cup.
    • A sink plunger just uses a rubber cup, which doesn't form a tight seal inside the toilet bowl.
  2. How to Unclog a Toilet: Schritt 2, Bild 1 von 1
    • Do not try to continuously flush a clogged toilet. This will likely result in an overflowing toilet bowl.
  3. How to Unclog a Toilet: Schritt 3, Bild 1 von 2 How to Unclog a Toilet: Schritt 3, Bild 2 von 2
    • If need be, use a pitcher or a cup to add more water to the toilet bowl so that the water level is about half-way full.
    • You'll want to add enough water so that the outer lip of the toilet plunger's rubber cup is completely submerged in order to create a tight seal.
  4. How to Unclog a Toilet: Schritt 4, Bild 1 von 2 How to Unclog a Toilet: Schritt 4, Bild 2 von 2
    • Insert the toilet plunger into the toilet bowl, making sure that the narrow bell-shaped flange at the end of the plunger is inserted into the drain at the bottom of the toilet bowl.
    • Once inserted, twist the plunger back and forth a couple of times to make sure it's firmly seated at the bottom of the toilet bowl.
  5. How to Unclog a Toilet: Schritt 5, Bild 1 von 2 How to Unclog a Toilet: Schritt 5, Bild 2 von 2
    • Start by slowly pushing down on the plunger. The inside of the plunger is full of air at first, so a quick downward thrust initially will push that air out quickly and splash water all over you and your bathroom.
    • If the plunger feels a bit stiff, you can run it under hot water to loosen up the rubber.
  6. How to Unclog a Toilet: Schritt 6, Bild 1 von 3 How to Unclog a Toilet: Schritt 6, Bild 2 von 3 How to Unclog a Toilet: Schritt 6, Bild 3 von 3
    • After making the initial plunge, the plunger should now be completely sealed around the toilet bowl's drain.
    • Next, vigourously force the plunger up and down several times, making sure to keep the plunger sealed to the bottom of the toilet bowl.
    • This method forces water in the drain to push and pull in both directions, eventually loosening the stuck material and unclogging the toilet.
    • After several thrusts, remove the plunger and repeat steps 5 and 6 until the toilet bowl drain clears.
  7. How to Unclog a Toilet: Schritt 7, Bild 1 von 2 How to Unclog a Toilet: Schritt 7, Bild 2 von 2
    • Once the toilet is unclogged, give the toilet a victory flush to clear out any residual matter left over from the clog.
  8. How to Unclog a Toilet: Schritt 8, Bild 1 von 1
    • There may be times when a plunger just doesn't get the job done. In that case, a toilet auger may be more useful and persuasive.
Ziellinie
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Craig Lloyd
35.546 Reputation
82 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 32
Insgesamt: 1,055
