Einleitung
If your DiseZeit Manual Coffee Grinder Z1M isn't spinning and grinding your coffee like how it should, this guide will help you unjam the grinder. This guide could also be helpful for routine cleanings of the grinder to prevent more jams, or cross-contamination when switching to new beans.
A manual coffee grinder can get clogged more often than an automatic coffee grinder used in commercial settings, and it can be confusing for individuals who enjoy making quality coffee at home to figure out how to clean out their personal grinding devices. All you will need for this guide is a place to wash the parts of the grinder.
Unscrew the bottom of your grinder where the coffee grounds are held and remove it from the grinder's body.
Take off the cap of the grinder that has the grinding handle on it by pulling it off.
Empty out the grinder body.
Put the cap of the grinder back on to the body.
Hold the handle on the cap still and turn the grinder upside down so you can see the bottom of the grinder body.
Look at the markings on the grinder to see which direction the dial should be turned to make the grounds finer or coarser.
Unscrew the dial towards the coarser setting until the dial becomes fully unscrewed from the grinder's body.
Check to see that the body of of the grinder has no more detachable parts in the center.
Gently wash the body of the grinder, the parts that were removed, and the base of the grinder that holds the coffee grounds using water and soap.
Fully dry each part of the grinder before reassembling.
Put the parts of the coffee grinder back together by following steps 5 through 8 in reverse order.
Enjoy your fresh coffee!
