Zum Hauptinhalt wechseln
How to Upgrade the Back Ports to USB-C on a GameBoy Advance
Was du brauchst
Einführungsvideo
  1. How to Upgrade the Back Ports to USB-C on a GameBoy Advance, Back Ports: Schritt 1, Bild 1 von 1
    • Turn off the Game Boy Advance SP completely. Then start cleaning the ports located on the back side of the case.
    • Use a cotton swab dipped in alcohol to gently scrub the inside of the port.
    • Do NOT apply too much pressure or use anything sharp to clean the ports.
    Frag FixBot
    Kommentar hinzufügen
  2. How to Upgrade the Back Ports to USB-C on a GameBoy Advance: Schritt 2, Bild 1 von 2 How to Upgrade the Back Ports to USB-C on a GameBoy Advance: Schritt 2, Bild 2 von 2
    • Use a Y00 screwdriver to remove the six Tri-Wing 1.5mm screws as you carefully disassemble your Game Boy into 4 parts: console, battery, back panel, and motherboard. The 6 screws are highlighted in the red circles.
    • The next few steps require knowledge of soldering and soldering safety guidelines. We strongly recommend that you review this video on how to safely solder.
    Frag FixBot
  3. How to Upgrade the Back Ports to USB-C on a GameBoy Advance: Schritt 3, Bild 1 von 1
    • Next, desolder the back port (highlighted in the red box) from the motherboard using a desoldering pump.
    • Take caution of the other parts of the motherboard as you desolder.
    • Clean off any remaining solder on the motherboard when you finish.
    Frag FixBot
  4. How to Upgrade the Back Ports to USB-C on a GameBoy Advance: Schritt 4, Bild 1 von 1
    • Align your USB-C port in place and ensure the bottom is facing downward.
    • Prepare the solder and iron for the next step.
    Frag FixBot
  5. How to Upgrade the Back Ports to USB-C on a GameBoy Advance: Schritt 5, Bild 1 von 2 How to Upgrade the Back Ports to USB-C on a GameBoy Advance: Schritt 5, Bild 2 von 2
    • Solder the sides that were previously connected to the old port.
    • After it is secured on both sides, solder the 4 metal pins on the back of the new USB-C port.
    • Once again, be careful not to damage/apply heat to any of the other parts of the motherboard.
    Frag FixBot
  6. How to Upgrade the Back Ports to USB-C on a GameBoy Advance: Schritt 6, Bild 1 von 1
    • To test for a successful connection, turn on the device.
    • If it doesn't turn on, ensure the port is connected to the correct points. If it isn't, use your soldering iron to solder the correct metal points.
    Frag FixBot
  7. How to Upgrade the Back Ports to USB-C on a GameBoy Advance: Schritt 7, Bild 1 von 1
    • Follow Steps 1 and 2 in reverse to reassemble.
    Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
CSU Los Angeles, Team 3-7, Grodsky Spring 2025 Mitglied von CSU Los Angeles, Team 3-7, Grodsky Spring 2025
CSULA-GRODSKY-S25S3G7
2 Mitglieder
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 46
Letzte 30 Tage: 188
Insgesamt: 797
