Zum Hauptinhalt wechseln
Einleitung
This guide teaches you how to upgrade your 5” UCONNECT firmware. The firmware included in this guide is for the UK and Europe UCONNECT 5” only. It won’t work on rest of world models.
    • Download Version Firmware (VP2 CO version)
    • Extract the zip file and copy it to the USB stick. A USB2 stick is advised with a capacity of at least 2GB and no more than 16GB.
    • If you get a not compatible error during this process upgrade to 12.00.24.01 followed by 13.00.57.05 before finally upgrading to 13.00.74.00. this will ensure you have a upgrade path.
    • If you are on a 13 .xx.xx.xx version already above should not be required. Any verion older than 12.xx.xx.x uplifting to 12.00.24.1 should get you there
    • You can can download the firmware from the fiat forum.Click here to download firmware
  1. Insert USB stick into Fiat 500 USB port
    • Insert USB stick into Fiat 500 USB port
    • Turn on engine (keep it running to avoid battery drain)
  2. Turn the Raido on pressing the power button
    • Turn the Raido on pressing the power button
    • Press contiune. To the safe driving message.
    • Mute the raido to avoid audo noise during upgrades.
    • Press Start
  3. The Firmware will start to upgrade If your FIAT 500 is an automatic you will hear the robotic arm charge. This is normal. The Raido may also go blank or the bar may dissapear.
    • The Firmware will start to upgrade
    • If your FIAT 500 is an automatic you will hear the robotic arm charge. This is normal. The Raido may also go blank or the bar may dissapear.
  4. One complete the unit will restart.
    • One complete the unit will restart.
    • Remove the USB Stick
Abschluss
Your firmware is up-to-date. Repeat if needed until you have uplifted to the latest version.
Tom
1.462 Reputation
4 Anleitungen geschrieben
2 Kommentare
Hallo ich brauche eure Hilfe. Neuen Radio MIT Navi zugekauft für 500L - der Original Radio war OHNE Navi! Leider hängt sich das Navi beim Starten immer nach kurzer Zeit auf!! Kann der neue Nav-Radio dem Steuergerät „angelernt“ werden? Danke für jede Hilfe! In zwei Fiat Werkstätten war ich schon, leider ohne Erfolg.
mamy - Antwort
Angeblich kann in einen Fiat (in meinem Fall 500L 2013) serienmäßig OHNE Radio mit NAV ausgerüstet, KEIN Radio MIT NAV eingebaut werden!? Kann da jemand helfen? Vielen Dank Manfredo
mamy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 23
Letzten 7 Tage: 173
Letzten 30 Tage: 678
Insgesamt: 5,684
