Zum Hauptinhalt wechseln
How to Wash and Dry a Patagonia Pack
Was du brauchst
    1. How to Wash and Dry a Patagonia Pack, Prepare the pack: Schritt 1, Bild 1 von 3 How to Wash and Dry a Patagonia Pack, Prepare the pack: Schritt 1, Bild 2 von 3 How to Wash and Dry a Patagonia Pack, Prepare the pack: Schritt 1, Bild 3 von 3
      • Open the pack and remove all contents.
      • Double-check every pocket—you never know what treasures or love notes might be hiding!
      • Shake out loose dirt and debris from the main compartment.
      • Open all pockets and smaller sections, then shake or brush out any remaining debris in those areas.
      Frag FixBot
      Kommentar hinzufügen
    2. How to Wash and Dry a Patagonia Pack: Schritt 2, Bild 1 von 3 How to Wash and Dry a Patagonia Pack: Schritt 2, Bild 2 von 3 How to Wash and Dry a Patagonia Pack: Schritt 2, Bild 3 von 3
      • Loosen all drawcords and cinches.
      • Flip the pack inside-out.
      • It might feel awkward, but don’t worry—packs are manufactured inside-out and can handle it!
      • Wipe or brush away any debris revealed during the flip. Pay special attention to the bottom corners and under binding tape where lint tends to collect.
      • Use a soft, dry brush to reach into tight crevices.
      Frag FixBot
    3. How to Wash and Dry a Patagonia Pack, Spot clean: Schritt 3, Bild 1 von 3 How to Wash and Dry a Patagonia Pack, Spot clean: Schritt 3, Bild 2 von 3 How to Wash and Dry a Patagonia Pack, Spot clean: Schritt 3, Bild 3 von 3
      • Mix a small amount of dish soap with warm water.
      • Use a soft brush to pre-treat any tough stains with the soapy water mixture.
      • Focus on shoulder straps, back panels, and bottom panels—these areas tend to collect the most grime.
      • See Spot Clean Technical Gear for more details.
      Frag FixBot
    4. How to Wash and Dry a Patagonia Pack, Hand wash (For foam-backed packs): Schritt 4, Bild 1 von 3 How to Wash and Dry a Patagonia Pack, Hand wash (For foam-backed packs): Schritt 4, Bild 2 von 3 How to Wash and Dry a Patagonia Pack, Hand wash (For foam-backed packs): Schritt 4, Bild 3 von 3
      • If your pack has integrated foam pieces, like a foam back, you must wash it by hand. For packs without foam, you can skip to Step 8 for machine washing directions.
      • Fill a tub or sink with warm water and add a biodegradable soap or detergent.
      • Any biodegradable liquid detergent free of dye will work. Look for labels like "organic" or "sensitive skin."
      • Submerge the pack and gently scrub it with a soft brush or sponge, paying extra attention to dirty or stained areas.
      • Flip the pack inside-out and right-side-out as needed to reach all areas.
      Frag FixBot
    5. How to Wash and Dry a Patagonia Pack, Rinse: Schritt 5, Bild 1 von 2 How to Wash and Dry a Patagonia Pack, Rinse: Schritt 5, Bild 2 von 2
      • Drain the dirty water.
      • Make sure you used biodegradable soap before dumping outside!
      • Rinse the backpack thoroughly with clean, cool water until all soap is gone.
      • If you're outside, a hose works great for this step!
      Frag FixBot
    6. How to Wash and Dry a Patagonia Pack, Hang to dry: Schritt 6, Bild 1 von 1
      • Flip the pack right-side-out so it dries in its natural shape.
      • Shake out excess water, especially from compartments where it can pool.
      • Hang the pack upside down to dry in a well-ventilated area, out of direct sunlight.
      Frag FixBot
    7. How to Wash and Dry a Patagonia Pack, All done!: Schritt 7, Bild 1 von 2 How to Wash and Dry a Patagonia Pack, All done!: Schritt 7, Bild 2 von 2
      • You did it!
      • Your pack is fresh and ready for more adventures.
      • Maybe vow to keep coffee mugs out of it next time 😉
      Frag FixBot
    8. How to Wash and Dry a Patagonia Pack, Machine wash (For packs without foam): Schritt 8, Bild 1 von 3 How to Wash and Dry a Patagonia Pack, Machine wash (For packs without foam): Schritt 8, Bild 2 von 3 How to Wash and Dry a Patagonia Pack, Machine wash (For packs without foam): Schritt 8, Bild 3 von 3
      • Only machine wash packs without foam. If your pack has integrated foam, see Step 4 for hand washing instructions.
      • The pictured item is a Black Hole® Cube but other examples include some Lightweight Travel Totes, cotton tote, and the Slope Runner Vest.
      • Some bags also have removable foam that can be taken out before machine washing.
      • Spot clean first with dish soap and warm water. See Spot Clean Technical Gear.
      • Open all zippers and loosen all cinches to allow for water flow. Fasten all buckles to prevent damage.
      • Wash inside-out if the interior is dirtier; right-side-out if the exterior needs more attention.
      Frag FixBot
    9. How to Wash and Dry a Patagonia Pack: Schritt 9, Bild 1 von 3 How to Wash and Dry a Patagonia Pack: Schritt 9, Bild 2 von 3 How to Wash and Dry a Patagonia Pack: Schritt 9, Bild 3 von 3
      • Use a front-loading machine or top-loading machine without an agitator (the central spindle). Agitators can damage packs by causing tangles, tears, or scrapes.
      • Place the pack in the washing machine with gentle, biodegradable laundry detergent.
      • Set the load size to small.
      • Set the water temperature to cold or warm.
      • Set the wash cycle to normal or gentle/delicate/permanent press.
      • Set the spin cycle to low or off.
      • Start the washing machine.
      Frag FixBot
    10. How to Wash and Dry a Patagonia Pack, Hang to dry: Schritt 10, Bild 1 von 2 How to Wash and Dry a Patagonia Pack, Hang to dry: Schritt 10, Bild 2 von 2
      • Hang the pack right-side-out in a well-ventilated, shaded area to air dry.
      • Don't put the pack in the dryer.
      Frag FixBot
      • Zippers last longer when they’re clean, dry, and free of debris or corrosive agents like saltwater, sweat, or toiletries.
      • Avoid using zipper lubricants unless absolutely necessary. If a clean zipper is still sticky, it may need to be sent in for repair.
      • Exception: Waterproof zippers on submersible packs require specific lubricants—check the manufacturer’s recommendations.
      Frag FixBot
Ziellinie
2 weitere Personen haben diese Anleitung absolviert.
Patagonia Mitglied von Patagonia
Community
9 Mitglieder
227 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 49
Letzte 30 Tage: 160
Insgesamt: 1,219
