Zum Hauptinhalt wechseln
How to Wire a RJ-45 KeyStone Jack
Was du brauchst
  1. How to Wire a RJ-45 KeyStone Jack, How to Wire a RJ-45 KeyStone Jack: Schritt 1, Bild 1 von 3 How to Wire a RJ-45 KeyStone Jack, How to Wire a RJ-45 KeyStone Jack: Schritt 1, Bild 2 von 3 How to Wire a RJ-45 KeyStone Jack, How to Wire a RJ-45 KeyStone Jack: Schritt 1, Bild 3 von 3
  2. How to Wire a RJ-45 KeyStone Jack: Schritt 2, Bild 1 von 3 How to Wire a RJ-45 KeyStone Jack: Schritt 2, Bild 2 von 3 How to Wire a RJ-45 KeyStone Jack: Schritt 2, Bild 3 von 3
    • Use your wire stripper to cut the outer sheath
    • Do Not Rotate more than 3-4 times as it will cut the wires underneath.
    • when the length of exposed wires are at a decent length (a little less than a thumbs length) separate the wires by color.
  3. How to Wire a RJ-45 KeyStone Jack: Schritt 3, Bild 1 von 3 How to Wire a RJ-45 KeyStone Jack: Schritt 3, Bild 2 von 3 How to Wire a RJ-45 KeyStone Jack: Schritt 3, Bild 3 von 3
    • on the keystone jack you will see colors. line the wires up to the corresponding colors (white blue - blue, white orange - orange, etc.)
    • use the punchdown tool with the longer side of the blade on the outside to punch the wires in and it will cut off the excess.
    • repeat for each color
  4. How to Wire a RJ-45 KeyStone Jack: Schritt 4, Bild 1 von 3 How to Wire a RJ-45 KeyStone Jack: Schritt 4, Bild 2 von 3 How to Wire a RJ-45 KeyStone Jack: Schritt 4, Bild 3 von 3
    • open up your mounting box
    • there should be a frame for your jack to snap into
  5. How to Wire a RJ-45 KeyStone Jack: Schritt 5, Bild 1 von 2 How to Wire a RJ-45 KeyStone Jack: Schritt 5, Bild 2 von 2
    • place the jack into the mounting box, there should be places for zip ties to hold the cable in place
    • place the cover on top and you are done with your cable!
    • test the line using a cable tester.
Abschluss
Make Sure to test with a cable tester
6 weitere Personen haben diese Anleitung absolviert.
Sams TechRepair Mitglied von Sams TechRepair
Business
1 Mitglied
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 80
Letzte 30 Tage: 272
Insgesamt: 23,140
