Zum Hauptinhalt wechseln
How to access hidden settings on RCA RT2806
  1. How to access hidden settings on RCA RT2806, Power: Schritt 1, Bild 1 von 1
    • Turn on your TV
  2. How to access hidden settings on RCA RT2806, Open the Menu: Schritt 2, Bild 1 von 2 How to access hidden settings on RCA RT2806, Open the Menu: Schritt 2, Bild 2 von 2
    • Open the menu, by pressing the menu button on the remote
  3. How to access hidden settings on RCA RT2806, NumPad Shortcut: Schritt 3, Bild 1 von 2 How to access hidden settings on RCA RT2806, NumPad Shortcut: Schritt 3, Bild 2 von 2
    • Press the following buttons quickly after opening the menu:
    • 1-1-4-7
    • This is a column of numbers on your NumPad
    • If it doesn't work, do it more quickly after opening the menu, and check your TV model number.
Abschluss
To close the new menu, press EXIT
2 weitere Personen haben diese Anleitung absolviert.
9021007
4.599 Reputation
25 Anleitungen geschrieben
3 Kommentare zur Anleitung
You can disable the dog logo on here under General Settings.
9021007 - Antwort
Thank you very much. This was driving me insane
Will McCreary -
Is there any way to save settings? Some settings are permanent, but specifically the overscan settings are reset to their original values when I power the screen off, whether by the remote power button, the power button on the screen itself. or by unplugging it.
Please advise.
Jyri Keir - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 61
Insgesamt: 3,682
