Zum Hauptinhalt wechseln
How to adjust Razor A steering column
  1. How to adjust Razor A steering column, How to adjust Razor A steering column: Schritt 1, Bild 1 von 2 How to adjust Razor A steering column, How to adjust Razor A steering column: Schritt 1, Bild 2 von 2
    • Locate the tightening assembly. The tightening assembly consists of:
    • An upper nut
    • A lower nut
  2. How to adjust Razor A steering column: Schritt 2, Bild 1 von 1
    • This step refers to clockwise and counterclockwise rotation. This is as viewed from the top.
    • If loosening the steering column, follow these steps:
    • Turn the upper nut counterclockwise.
    • Turn the lower nut counterclockwise until it is tight against the upper nut.
    • If the steering column is still too tight, repeat the above two steps until reaching the desired steering column looseness.
    • If tightening the steering column, follow these steps:
    • Turn the lower nut clockwise until reaching the desired steering column tightness.
    • Turn the upper nut clockwise until it is tight against the lower nut.
Ziellinie
4 weitere Personen haben diese Anleitung absolviert.
Jordyn
565 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 9-13, Amido Fall 2012 Mitglied von Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 Mitglieder
10 Anleitungen geschrieben
8 Kommentare zur Anleitung
what move it with your hands? - didn't help
Heather McCasland - Antwort
I couldn't turn this by hand. not sure who writes this advice. trying a pipe wrench.
jmackenzie1234 -
Thanks you! Why doesn't the owners manual have this?
Jessica - Antwort
Thanks for the instructions. They helped me fix my son’s scooter.
That Dude - Antwort
Thank you for showing the way how to adjust Razor scooter. This instruction help me to adjust my scooter.
Jessie Allen - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 18
Letzte 30 Tage: 85
Insgesamt: 43,464
