Zum Hauptinhalt wechseln
How to adjust a Chevrolet Corvair steering box
Was du brauchst
  1. How to adjust a Chevrolet Corvair steering box, How to adjust a Chevrolet Corvair steering box: Schritt 1, Bild 1 von 1
    • Open the (front) hood of the car.
    • On the drivers side of the luggage compartment is a black seal.
  2. How to adjust a Chevrolet Corvair steering box: Schritt 2, Bild 1 von 1
    • Remove the black seal.
    • Under the seal is the adjustment screw and locking nut.
  3. How to adjust a Chevrolet Corvair steering box: Schritt 3, Bild 1 von 1
    • If the screw threads do not rise above the locking nut then STOP: The steering box is worn out, it is time to rebuild it, or replace it! Failure to do so could result in your steering system failing.
    • Loosen the Locking nut, so the set screw can be turned with a flat head screwdriver.
    • With the wheels straight and the steering wheel centered. Turn the lash adjustment screw clockwise until it stops, but don't force it any farther!
    • Making sure that the screw does not turn, carefully tighten the locking nut.
  4. How to adjust a Chevrolet Corvair steering box: Schritt 4, Bild 1 von 1
    • Close the hood, drive around and check the steering wheel play.
    • If the play is still too loose, then repeat steps 2 and 3.
    • If the steering wheel does not return to center after making a turn then it is too tight. This can cause unnecessary wear and damage your steering box! Return to step 2, but instead of tightening the lash screw, loosen it a quarter turn at a time and recheck.
Abschluss
Congratulations! Your steering box should now have a minimal amount of play!
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Noah
568 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 6-33, Regan Fall 2012 Mitglied von Cal Poly, Team 6-33, Regan Fall 2012
CPSU-REGAN-F12S6G33
3 Mitglieder
7 Anleitungen geschrieben
3 Kommentare
I have over tighten the steering box. I have loosen the box all the way ,but it steel stick
larryboyd23 - Antwort
This procedure skips several important steps, including setting the preload prior to adjusting the lash screw. Hint - you need a torque wrench to do it correctly. It's also advisable to check all the steering components, especially the pitman arm bushing, as the cause of steering play before blaming the steering box. I've seen several steering boxes ruined by over tightening the lash screw when the box wasn't even the problem to begin with.
Jim Thomas - Antwort
great post, thanks for sharing it. Keep Posting.
https://www.sarexports.com/product/steer...
Raman Malik - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 30
Insgesamt: 27,091
