Zum Hauptinhalt wechseln
How to align Razor A steering
Was du brauchst
  1. How to align Razor A steering, How to align Razor A steering: Schritt 1, Bild 1 von 3 How to align Razor A steering, How to align Razor A steering: Schritt 1, Bild 2 von 3 How to align Razor A steering, How to align Razor A steering: Schritt 1, Bild 3 von 3
    • Locate the collar clamp near the base of the steering column.
    • Insert a 3/16" Allen wrench into the screw in the collar clamp and loosen it.
    • The collar clamp will be free to move and may slide around the steering column. When reassembling, return it to its original position.
  2. How to align Razor A steering: Schritt 2, Bild 1 von 2 How to align Razor A steering: Schritt 2, Bild 2 von 2
    • Firmly grasp the steering column and turn the wheel by hand.
    • View the scooter along the steering column. Be sure the wheel is perpendicular to the handlebars.
    • The second picture above shows a correct alignment of the steering column from this view.
Ziellinie
17 weitere Personen haben diese Anleitung absolviert.
Jordyn
565 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 9-13, Amido Fall 2012 Mitglied von Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 Mitglieder
10 Anleitungen geschrieben
4 Kommentare zur Anleitung
This is so unhelpful.
Linh Tran - Antwort Teilen
Great guide! Thanks so much helped me to fix my old scooter and save approx. $50
Max Kittens - Antwort Teilen
Wow, fixed all the kids scooters on the block….THANK YOU!!!!!
Kathy Earhart - Antwort Teilen
It worked for me for a little, but after a while the fix stopped working and i am back to where i started, and it is now as tight as it will go. They should really make the scooters better. The guide was really helpful, so thanks so much!
Alan Weinberg - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 57
Insgesamt: 31,457
