Zum Hauptinhalt wechseln
How to apply scratch-proof coating
Was du brauchst
  1. How to apply scratch-proof coating, How to apply scratch-proof coating: Schritt 1, Bild 1 von 1
    • Use Liquid Sapphire scratch proof nanotechnology coating
  2. How to apply scratch-proof coating: Schritt 2, Bild 1 von 1
    • Add 3 drops of Liquid Sapphire to the LCD
  3. How to apply scratch-proof coating: Schritt 3, Bild 1 von 1
    • With a microfibre cloth wipe up and down until the LCD surface is covered.
  4. How to apply scratch-proof coating: Schritt 4, Bild 1 von 1
    • keep wiping up and down until a Grey/White coat starts forming, it will look similar to a widow smear.
  5. How to apply scratch-proof coating: Schritt 5, Bild 1 von 1
    • Leave to dry for 10 minuets and then buff off with a shammy (Chamois) Repeat the steps 3 times in total. The device can be used immediately. Keep clear of any objects that might scratch your screen until fully cured, in 24hrs.
    • Here is a coin scratching an iphone 5 LCD, watch and see what happens.
Abschluss
30 weitere Nutzer:innen haben diese Anleitung absolviert.
Irish Jack
2.452 Reputation
1 Anleitung geschrieben
4 Kommentare
Dead product link
Jdwashere - Antwort
Does this product/method work if you already have a couple of light scratches on the screen?
Thank you,
Gary
Gary Zehnpfennig - Antwort
Does this product/method work if you already have a couple of light scratches on the screen.
Does this product/method work if you already have a couple of light scratches on the screen —
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 14
Letzte 30 Tage: 46
Insgesamt: 16,307
