Einleitung
Bleeding brakes is a key part of automotive brake repairs. Whenever the brake lines are replaced or the brake fluid is drained, the lines must be bled to remove all air that may be present. A brake system with air in it is easy to diagnose, because the brake pedal inside the car will usually feel "spongey," and may go all the way to the floor when depressed.
The following procedure uses a Motive Power Bleeder, rather than traditional manual bleeding. The Power Bleeder is significantly easier to use than other methods and is not particularly expensive. (Note: iFixit is in no way affiliated with or supported by Motive. We just like their stuff!)
Was du brauchst
Jack up the four corners of the car and remove the wheels.
Remove the cap from the brake fluid reservoir and set it aside.
Fill the reservoir to the maximum fill line with brake fluid.
Place the Power Bleeder hose through the Power Bleeder cap and place the cap on the brake fluid reservoir.
Tighten the cap, ensuring that the gasket inside seats properly.
Place the cap on the empty Power Bleeder tank and tighten it.
Pressurize the Power Bleeder to 10 psi and check all connections for leaks.
Before making any adjustments or continuing, relieve the pressure in the Power Bleeder by slowly loosening the cap on the tank.
Remove the cap from the Power Bleeder tank and fill the tank with two quarts of brake fluid.
Replace the Power Bleeder cap and tighten it fully.
Pressurize the system to a level between 15 and 20 psi.
Attach an open end of the bleed tube to the bleed valve on the brake caliper.
Place the other end of the bleed valve in a suitable container, such as a bottle or drain pan.
Use an 8 mm open end wrench to loosen the bleed screw on the caliper.
Brake fluid will begin to flow through the bleed tube with many air bubbles. Once the air bubbles stop completely, tighten the bleed screw to close the bleed valve.
Repeat steps 5 and 6 for the other three brake calipers, moving to passenger rear, driver front, and finally passenger front.
Tilt the tank so that the pick-up tube is not submerged in brake fluid.
Open the bleed valve on the passenger side front caliper until air flows from the tank into the fluid reservoir and the brake fluid reservoir falls just below the maximum fill line. Close the bleed valve once the fluid in the reservoir is at the appropriate level.
Slowly loosen the cap on the bleeder tank to relieve the pressure.
Remove the cap from the brake fluid reservoir and top it off, if necessary.
Reinstall the original brake fluid reservoir cap.
Place the wheels back on the car and lower it to the ground; you're done!
4 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
let me ask a question about this procedure, my calipers are stock, and the fronts have three bleed ports a piece, which port do I bleed first?
