Zum Hauptinhalt wechseln
How to change the grips on a golf club
Was du brauchst
  1. How to change the grips on a golf club, Grip: Schritt 1, Bild 1 von 2 How to change the grips on a golf club, Grip: Schritt 1, Bild 2 von 2
    • Tighten golf club on vice clamp. Align the golf club so that the club face is vertical.
    • Note: Make sure you place container underneath the grip to catch excess mineral spray in later steps.
  2. How to change the grips on a golf club: Schritt 2, Bild 1 von 2 How to change the grips on a golf club: Schritt 2, Bild 2 von 2
    • With the xacto knife cut the old grip off of the club.
    • Remove grip from club.
  3. How to change the grips on a golf club: Schritt 3, Bild 1 von 2 How to change the grips on a golf club: Schritt 3, Bild 2 von 2
    • Measure the amount of double-sided tape necessary to cover the area of your grip.
    • Place the tape on the club so that it is centered and an extra inch comes off the end of the club.
  4. How to change the grips on a golf club: Schritt 4, Bild 1 von 2 How to change the grips on a golf club: Schritt 4, Bild 2 von 2
    • Squirt mineral spirits on the tape.
    • Make sure you drench the tape in mineral spirits.
    • Note: it is safe to get mineral spirits on your skin, it is non-toxic.
  5. How to change the grips on a golf club: Schritt 5, Bild 1 von 3 How to change the grips on a golf club: Schritt 5, Bild 2 von 3 How to change the grips on a golf club: Schritt 5, Bild 3 von 3
    • While the tape still has mineral spray on it, quickly slide the grip all the way down.
  6. How to change the grips on a golf club: Schritt 6, Bild 1 von 1
    • Wait 1-2 hours for the mineral spray to dry.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Esteban Ortega
147 Reputation
1 Anleitung geschrieben
Cal Poly, Team 30-2, Green Spring 2015 Mitglied von Cal Poly, Team 30-2, Green Spring 2015
CPSU-GREEN-S15S30G2
4 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
Muy bueno. Gracias
Matias Doro Altan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 1,011
