Zum Hauptinhalt wechseln
How to check Black and Decker 3-Cup Rice Cooker continuity
Was du brauchst
  1. How to check Black and Decker 3-Cup Rice Cooker continuity, Remove the Lid and Bowl: Schritt 1, Bild 1 von 1
    • Make sure the device is unplugged before beginning disassembly!
    • Lift the lid and bowl from the top of the device.
    Frag FixBot
    Kommentar hinzufügen
  2. How to check Black and Decker 3-Cup Rice Cooker continuity, Turn the Device Upside-Down: Schritt 2, Bild 1 von 1
    • Turn the device upside-down, so that the four legs of the device point upwards.
    Frag FixBot
  3. How to check Black and Decker 3-Cup Rice Cooker continuity, Remove the Rubber Cushions: Schritt 3, Bild 1 von 2 How to check Black and Decker 3-Cup Rice Cooker continuity, Remove the Rubber Cushions: Schritt 3, Bild 2 von 2
    • Each of the four legs has a rubber cushion on its bottom. For each cushion, insert a plastic opening tool between the plastic leg and rubber cushion, and pry off the rubber cushion.
    Frag FixBot
  4. How to check Black and Decker 3-Cup Rice Cooker continuity, Remove the Spanning Screw: Schritt 4, Bild 1 von 1
    • Using a spanner screwdriver, remove the one 10mm long 7mm diameter spanner screw from the side of the brass panel.
    Frag FixBot
  5. How to check Black and Decker 3-Cup Rice Cooker continuity, Remove the Leg Screws: Schritt 5, Bild 1 von 1
    • Using a Phillips screwdriver, remove the 10mm long 7mm diameter Phillips-head screws from the inside of all four legs.
    • The smaller leg at the bottom is now loose and not attached to the device. Set it aside.
    Frag FixBot
  6. How to check Black and Decker 3-Cup Rice Cooker continuity, Remove the Brass Plate: Schritt 6, Bild 1 von 1
    • Lift the brass plate off the device and set it aside.
    Frag FixBot
  7. How to check Black and Decker 3-Cup Rice Cooker continuity, Color the Wires: Schritt 7, Bild 1 von 2 How to check Black and Decker 3-Cup Rice Cooker continuity, Color the Wires: Schritt 7, Bild 2 von 2
    • Color coordinating wire groups make it easier to identify the wire groups during reassembly.
    • Inside the device, there are three junctions with wires joined by Phillips-head screws. The first is connected to two wires, and the other two are connected to three wires each.
    • Unscrew the screw at the junction near the opposite side of the device from the front panel.
    • Label each of the two wires at this junction with a single color of tape.
    Frag FixBot
  8. How to check Black and Decker 3-Cup Rice Cooker continuity, Label the Second Wire Junction: Schritt 8, Bild 1 von 2 How to check Black and Decker 3-Cup Rice Cooker continuity, Label the Second Wire Junction: Schritt 8, Bild 2 von 2
    • Unscrew the screw at the junction just clockwise from the button panel.
    • Label the three wires of this junction with tape of a second color.
    Frag FixBot
  9. How to check Black and Decker 3-Cup Rice Cooker continuity, Label the Third Wire Junction: Schritt 9, Bild 1 von 2 How to check Black and Decker 3-Cup Rice Cooker continuity, Label the Third Wire Junction: Schritt 9, Bild 2 von 2
    • Unscrew the screw from the wire junction just behind the front panel.
    • Label the three wires at this junction with a third color of tape.
    Frag FixBot
  10. How to check Black and Decker 3-Cup Rice Cooker continuity, Plug the Device into an Outlet: Schritt 10, Bild 1 von 1
    • During these steps, DO NOT touch the wires directly. You may be electrocuted.
    • Plug the device's power cord into a functioning outlet.
    Frag FixBot
  11. How to check Black and Decker 3-Cup Rice Cooker continuity, Check the Voltage between the Wires: Schritt 11, Bild 1 von 1
    • Locate the two wires which are connected directly to the power cord. Unlike the other wires, they are sheathed in a particularly thick, dot-textured plastic.
    • Make sure the voltmeter is on and set to a setting beween 120 and 500V. For most voltmeters the proper setting for this is the 200V setting.
    • Attach one of the voltmeter's probes to the metal portions of each of the two wires connected to the power cord's end on the device
    • The voltmeter should read a number significantly above 20V. A reading between 100 and 150 V indicates that the device is getting enough power. A lower number indicates the power cord is broken.
    Frag FixBot
Abschluss
This guide alters no parts of the device, so no reassembly is needed from these steps.
Cal Poly, Team 12-1, Forte Fall 2014 Mitglied von Cal Poly, Team 12-1, Forte Fall 2014
CPSU-FORTE-F14S12G1
5 Mitglieder
14 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 31
Insgesamt: 1,712
