Einleitung
If your LCD screen doesn't seem broken, you should check that it is properly connected to the motherboard. This is a much cheaper fix than buying a new LCD screen for the camera.
Was du brauchst
Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
Fold back the LCD screen and check that the cable coming from the screen is securely fastened to the motherboard.
