Was du brauchst
Use a Phillips #2 screwdriver to remove the two screws on the top of the device toward the back.
Remove the plastic cover by lifting up the back and pulling it away from the faceplate.
Now that the device is open, you can check for any blown fuses that may need to be replaced.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
