Zum Hauptinhalt wechseln
How to clean Epson Stylus C84 ink pad
Was du brauchst
  1. How to clean Epson Stylus C84 ink pad, Removing the Back Panel: Schritt 1, Bild 1 von 2 How to clean Epson Stylus C84 ink pad, Removing the Back Panel: Schritt 1, Bild 2 von 2
    • Turn the printer around so the printer's front is facing away from you. Then, remove the rounded black panel from the paper guide by lifting it straight up.
    • Left Panel
    • Right Panel
    • Printer Front
    • Back Panel
  2. How to clean Epson Stylus C84 ink pad, Removing the "Parallel" Cover: Schritt 2, Bild 1 von 3 How to clean Epson Stylus C84 ink pad, Removing the "Parallel" Cover: Schritt 2, Bild 2 von 3 How to clean Epson Stylus C84 ink pad, Removing the "Parallel" Cover: Schritt 2, Bild 3 von 3
    • Wedge the flat end of the spudger between the top of the “Parallel” cover and the right panel, and gently pry the upper edge cover away. Completely remove the cover by hand if necessary. The Parallel and USB ports should be exposed.
  3. How to clean Epson Stylus C84 ink pad, Releasing the Prongs: Schritt 3, Bild 1 von 1
    • Next, turn the printer so that it's laying on its front side.
    • Locate the two plastic prongs on the bottom of the right panel.
    • Gently pinch the prongs together and push them with your fingers through the clips until they are free.
    • Do not use extreme force or bend the prongs in such a way that they break.
  4. How to clean Epson Stylus C84 ink pad, Pushing In the Interior Tabs: Schritt 4, Bild 1 von 3 How to clean Epson Stylus C84 ink pad, Pushing In the Interior Tabs: Schritt 4, Bild 2 von 3 How to clean Epson Stylus C84 ink pad, Pushing In the Interior Tabs: Schritt 4, Bild 3 von 3
    • Wedge a wide-tipped blue plastic opening tool inside the gray tab on the upper left-hand corner of the right panel, next to the arrow.
  5. How to clean Epson Stylus C84 ink pad, Releasing the Interior Tabs: Schritt 5, Bild 1 von 2 How to clean Epson Stylus C84 ink pad, Releasing the Interior Tabs: Schritt 5, Bild 2 von 2
    • Push in the gray tab until it becomes separated from the rest of the panel.
  6. How to clean Epson Stylus C84 ink pad, Holding the Right Panel in Place: Schritt 6, Bild 1 von 2 How to clean Epson Stylus C84 ink pad, Holding the Right Panel in Place: Schritt 6, Bild 2 von 2
    • Set the printer back down on its bottom.
    • Wedge one of the blue plastic separators between the back of the right panel and the rest of the printer’s housing to keep it separated.
  7. How to clean Epson Stylus C84 ink pad, Unclipping the Right Panel: Schritt 7, Bild 1 von 1
    • Turn the printer around so the front is facing toward you.
    • Open the printer’s cover, place your hand inside the right panel and unclip it from the rest of the printer with your thumb and forefinger.
    • Do not use extreme force when unclipping the panel.
  8. How to clean Epson Stylus C84 ink pad, Holding the Separated Right Panel: Schritt 8, Bild 1 von 1
    • Wedge a blue plastic separator between the plastic housing and the rest of the right panel and push the panel out from the inside to free it.
  9. How to clean Epson Stylus C84 ink pad, Removing the Right Panel: Schritt 9, Bild 1 von 1
    • Gently push the panel to the right to separate it from the printer.
  10. How to clean Epson Stylus C84 ink pad, Releasing the Ink Cartridge Carrier: Schritt 10, Bild 1 von 2 How to clean Epson Stylus C84 ink pad, Releasing the Ink Cartridge Carrier: Schritt 10, Bild 2 von 2
    • Use the flat end of the spudger to push the white button next to the ink cartridge carrier.
  11. How to clean Epson Stylus C84 ink pad, Manually Sliding the Ink Cartridge Carrier: Schritt 11, Bild 1 von 1
    • Gently slide the ink cartridge carrier by hand to the left to gain access to the inside of the left panel.
  12. How to clean Epson Stylus C84 ink pad, Removing the Left Panel's Prongs: Schritt 12, Bild 1 von 2 How to clean Epson Stylus C84 ink pad, Removing the Left Panel's Prongs: Schritt 12, Bild 2 von 2
    • Turn the printer so that it's on its front side again. Now there are two sets of prongs to undo for the left panel. Repeat step #2 for each set of prongs.
    • Do not use extreme force when removing the prongs.
  13. How to clean Epson Stylus C84 ink pad, Unclipping the Left Panel Upper Notch: Schritt 13, Bild 1 von 3 How to clean Epson Stylus C84 ink pad, Unclipping the Left Panel Upper Notch: Schritt 13, Bild 2 von 3 How to clean Epson Stylus C84 ink pad, Unclipping the Left Panel Upper Notch: Schritt 13, Bild 3 von 3
    • Wedge a blue plastic separator in the gray tab on the upper right-hand corner of the left panel.
    • Unclip the panel from inside the printer, and remove it.
  14. How to clean Epson Stylus C84 ink pad, Unclipping the Back Panel: Schritt 14, Bild 1 von 3 How to clean Epson Stylus C84 ink pad, Unclipping the Back Panel: Schritt 14, Bild 2 von 3 How to clean Epson Stylus C84 ink pad, Unclipping the Back Panel: Schritt 14, Bild 3 von 3
    • Turn the printer around so the front is facing away. Use three wide-tip blue plastic opening tools and place them inside the notches on the back panel of the printer.
  15. How to clean Epson Stylus C84 ink pad, Separating the Notches: Schritt 15, Bild 1 von 2 How to clean Epson Stylus C84 ink pad, Separating the Notches: Schritt 15, Bild 2 von 2
    • Push on each notch until the retaining tabs are separated from the back plastic cover.
  16. How to clean Epson Stylus C84 ink pad, Releasing the Tabs: Schritt 16, Bild 1 von 2 How to clean Epson Stylus C84 ink pad, Releasing the Tabs: Schritt 16, Bild 2 von 2
    • Turn the printer around so the front is facing you and gently push up on each tab of the front plastic panel, above the arrows. Make sure the prongs are detached from the clips.
  17. How to clean Epson Stylus C84 ink pad, Removing the Casing: Schritt 17, Bild 1 von 3 How to clean Epson Stylus C84 ink pad, Removing the Casing: Schritt 17, Bild 2 von 3 How to clean Epson Stylus C84 ink pad, Removing the Casing: Schritt 17, Bild 3 von 3
    • Gently pull the plastic housing upward to remove the back panel and reveal the inner components of the printer.
  18. How to clean Epson Stylus C84 ink pad, How to clean Epson Stylus C84 ink pad: Schritt 18, Bild 1 von 2 How to clean Epson Stylus C84 ink pad, How to clean Epson Stylus C84 ink pad: Schritt 18, Bild 2 von 2
    • Locate the porous pad inside the metal housing at the front of the printer.
  19. How to clean Epson Stylus C84 ink pad: Schritt 19, Bild 1 von 1
    • Push down on the upper left-hand corner of porous pad with the flat end of the spudger.
  20. How to clean Epson Stylus C84 ink pad: Schritt 20, Bild 1 von 3 How to clean Epson Stylus C84 ink pad: Schritt 20, Bild 2 von 3 How to clean Epson Stylus C84 ink pad: Schritt 20, Bild 3 von 3
    • Use the spudger to pry the right-hand corner of the porous pad from underneath the right edge of the metal housing.
  21. How to clean Epson Stylus C84 ink pad: Schritt 21, Bild 1 von 2 How to clean Epson Stylus C84 ink pad: Schritt 21, Bild 2 von 2
    • Once the pad's corner is free, remove the rest of the pad from the housing by hand. Pinch the upper-right hand corner and carefully peel the pad away from the housing
    • Take the porous pad to a sink, and turn on the faucet until warm water comes out. Hold the edges of the pad with both hands and rinse the inked porous pad with a gentle flow of warm water.
    • When the water flowing through the pad is clear, turn the faucet off. Shake the wet pad over the sink to remove any excess water.
    • Place the wet pad on two clean, dry paper towels. Let the pad air dry from 45 minutes to 1 hour.
    • Make sure the two paper towels are stacked on top of each other, to form two layers for the pad's moisture to soak into.
    • Do not leave the wet pad in extremely hot temperatures.
    • Replace your dirty disposable gloves with a pair of new, clean ones as you prepare to re-insert the pad.
Abschluss
To re-insert the clean, dry porous pad, place it back in the printer housing, and line up the holes on the black plastic base with the holes in the pad. Use the spudger to tuck in the pad underneath the metal lips. Use the spudger to make sure the pad is flush with the metal lips of the housing, and the plastic prongs in the base stick out.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013 Mitglied von UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G3
3 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Great tutorial, thanks for it. Those plastic casings are so hard to open, I wish they'd make them with screws :)
Boris Bogislaw - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 48
Letzte 30 Tage: 89
Insgesamt: 2,313
