Was du brauchst
Use a Phillips #2 screwdriver to remove the two screws on the top of the device toward the back.
Remove the plastic cover by lifting up the back and pulling it away from the faceplate.
Use a Phillips #2 screwdriver to remove the two screws at the base of the disk drive.
Use the screwdriver to remove two screws on either side of the silver security bar.
Turn disc drive over so you can see the gears on the bottom.
Using a cotton swap or a cleansing cloth and alcohol, gently rub the gears ridding of any debris and dust.
You can also use a compressed air can as well. Just point the nozzle at the gears and spray with the compressed air.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
