Einleitung
Corrosion usually occurs in the battery compartment. It appears as a light blue coating on any metal components and prevents power from flowing in the camera.
Ersatzteile
Kein Ersatzteil erforderlich.
    • In this guide we will be referring to 'left'and 'right' as though the camera's front (the part that says Nikon) facing you.
    • Use a quarter to twist open the one large screw on the bottom case. (No picture available.)
  1. Pull up on the tab to remove the batteries.
    • Pull up on the tab to remove the batteries.
    • Note: The batteries will probably fall out of their holder.
  2. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Erfolgreich repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  3. Your camera should look something like this.
    • Your camera should look something like this.
    • Clean the marked areas with a cotton swab soaked in CLR or vinegar.
  4. Corrosion appears as the bluish build-up you see in this picture. Scrub with a cotton swab until it has visibly decreased.
    • Corrosion appears as the bluish build-up you see in this picture. Scrub with a cotton swab until it has visibly decreased.
  5. All cleaned up!
    • All cleaned up!
Abschluss
Reinsert the batteries by following the instructions backwards. If it's still not getting power, head over to our battery compartment replacement guide. Note: It may be tough to find replacement parts.
3 weitere Nutzer haben diese Anleitung absolviert.
Zachary Phillips
205 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 25-26, Garner Spring 2011 Mitglied von Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Mitglieder
7 Anleitungen geschrieben
Wow it working thanks for assisting me. I used vinegar to clean my camera so it working now
lazarusmolai - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 61
Insgesamt: 11,924
