Einleitung
After long time in use, the laptop becomes hotter than usual due to poor ventilation system.
To make laptop cooler, more stable and longer life expectancy. we should do maintain its ventilation system
Was du brauchst
This laptop was bought in 2008 and it have never been disassembled to maintain. Before maintaince, we should turn it off and unplug it for AC source.
Now, turn the laptop upside-down. We push 2 buttons to take out the battery. Then remove 6 screws to open the cover as shown in the picture
After unscrewing, we lift up leftside of the cover and gently shake it to take out.
Take care of the small plastic patches. Do not make them broken. They help to lock the cover firmly to the bottom housing of the laptop
This model is designed perfectly for maintenance. We can see all the main components after removing the cover.
We can maintain the ventilation system without removing RAM, HDD, Wifi Card, keyboard like other models.
There are 4 screws numbered from 1 to 4. We should remove them in order of sequence, from 1 to 4. Use screwdriver to twist anticlockwise
Unplug Fan jack. Then gently lift up the heat sink and pull it towards you to take it out
CPU use Thermal Glue and GPU use Thermal Pad to transfer heat to the heat sink. After years, they become dry, which reduce ability to transfer heat. We have to replace both Glue and Pad.
Use soft cloth (or wet tissue), soft cotton ear-pick and Acetone to clean 2 chips (CPU, GPU), heat sink thoroughly.
Take out the fan wing by lift it up. There's a magnetic ring that sucks stator coil. We can feel a little hard to pull out. Just give some more force and we can take out easily without breaking it.
Afterwards, use Grease (a kind of component to lubricate fan axis). This help to make fan operate silently and fast
Remember to clean fan wing, fan base thoroughly
Now we clean the housing. Remove the dust stuck inside and outside ventilation leaves by a brush. Using a high pressure pump to clean is much better in this situation
After cleaning fan and its housing. We assemble fan wing back to fan base. The n assemble fan set back to the housing.
Take care of the marks to assemble the fan correctly
Apply new Thermal Glue and Thermal Pad to CPU and GPU chips. Be ready to reassemble the heat sink!
Put back heat sink into its right position. Adjust it so that screws lay on their right position.
Screw in order of sequence, from 1 to 4 firmly
Reconnect the fan jack to the fan outlet on the mainboard
Reassemble the back cover
Reassemble the battery
Now it is finished. Open your laptop. Start the OS. Use some applications such as "CPUID Hardware Monitor", "Temp core", "Everest Ultimate Edition" to check temperature of CPU, GPU, Hard disk, RAM. Their temperature is now lower than before.
End of guide! Thanks you for your attention!
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Excellent guide! I did this to my laptop several times.
I usually find a lot of dust in the inside square corners of the fan housing. Excellent machine with this minor flaw that needs to be addressed every 2 years in my experience.
It runs Lubuntu extremely fast and outperforms i3 and i5 machines with just 2GB Ram and no Windslows...
KH02, are you using Lubuntu on this model? 4920? Did you find all drivers for it to work on Linux?
I dug up my old 4920G a week ago, I just ordered a new processor for it, going from T5550 up to the T9500. I got 4gb ram already, and a 64gb ssd to replace the HD with.
