Zum Hauptinhalt wechseln
How to clean and maintain your Vape Mod
Was du brauchst
  1. How to clean and maintain your Vape Mod, How to clean and maintain your Vape Mod: Schritt 1, Bild 1 von 3 How to clean and maintain your Vape Mod, How to clean and maintain your Vape Mod: Schritt 1, Bild 2 von 3 How to clean and maintain your Vape Mod, How to clean and maintain your Vape Mod: Schritt 1, Bild 3 von 3
    • Although maintenance for your Vape Mod shouldn't be dangerous, it can be messy. It is recommended to do this on top of a paper towel.
    • Start by removing the top cap of your Vape Mod.
  2. How to clean and maintain your Vape Mod: Schritt 2, Bild 1 von 3 How to clean and maintain your Vape Mod: Schritt 2, Bild 2 von 3 How to clean and maintain your Vape Mod: Schritt 2, Bild 3 von 3
    • Unscrew RDA (rebuildable dripping atomizer) and take it off.
  3. How to clean and maintain your Vape Mod: Schritt 3, Bild 1 von 3 How to clean and maintain your Vape Mod: Schritt 3, Bild 2 von 3 How to clean and maintain your Vape Mod: Schritt 3, Bild 3 von 3
    • Many Vape Mods are different, you might have to take out your battery in a different way than shown.
    • At the bottom of the tube, unscrew the firing pin.
    • Take the battery out of the Vape Mod.
  4. How to clean and maintain your Vape Mod: Schritt 4, Bild 1 von 3 How to clean and maintain your Vape Mod: Schritt 4, Bild 2 von 3 How to clean and maintain your Vape Mod: Schritt 4, Bild 3 von 3
    • Inspect all of the parts that will need to be cleaned:
    • The firing pin
    • The RDA threading
    • The bottom of the inside of the tube
  5. How to clean and maintain your Vape Mod: Schritt 5, Bild 1 von 2 How to clean and maintain your Vape Mod: Schritt 5, Bild 2 von 2
    • Clean the Firing pin by dipping a paper towel into hot water.
    • Carefully rotate the hot towel around the middle area, rubbing the grime away.
  6. How to clean and maintain your Vape Mod: Schritt 6, Bild 1 von 3 How to clean and maintain your Vape Mod: Schritt 6, Bild 2 von 3 How to clean and maintain your Vape Mod: Schritt 6, Bild 3 von 3
    • Get a new paper towel wet with the hot water.
    • Clean the RDA threading by rotating the wet paper towel back and forth across it.
  7. How to clean and maintain your Vape Mod: Schritt 7, Bild 1 von 3 How to clean and maintain your Vape Mod: Schritt 7, Bild 2 von 3 How to clean and maintain your Vape Mod: Schritt 7, Bild 3 von 3
    • Twist it until it can easily fit inside of the tube.
    • Use your finger or another long tool to rotate the paper towel along the sides and the bottom of the tube.
  8. How to clean and maintain your Vape Mod: Schritt 8, Bild 1 von 3 How to clean and maintain your Vape Mod: Schritt 8, Bild 2 von 3 How to clean and maintain your Vape Mod: Schritt 8, Bild 3 von 3
    • Put your Vape Mod back together by doing steps 1 - 2 in reverse. (Leave the mouthpiece of the top cap off).
    • Careful, firing your Vape Mod produces heat and can make the device HOT!
    • Fire your Vape Mod. If the coils are heating up, it has been fixed!
Abschluss
If your Vape Mod is still not firing, consider getting a new build.
13 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 14-3, Green Fall 2015 Mitglied von Cal Poly, Team 14-3, Green Fall 2015
CPSU-GREEN-F15S14G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 48
Insgesamt: 10,647
