Einleitung
This guide will explain how to do simple maintenance on your Avanti 308YWT evaporator tray. This involves simply removing and cleaning the tray. If the evaporator tray is not cleaned it could cause the fridge to start leaking, which could eventually damage the floor.
Before starting, unplug the refrigerator.
Go to the bottom of the back side of the refrigerator and locate the cut out where the compressor and evaporator are stored.
Remove the evaporator tray by simply pulling up and out the tray. make sure that none of the liquid spills.
The evaporator tray might have ice build up on it. You can remove this ice by pouring warm water on the tray. After the ice is melted, clean the tray with warm water and soap.
7 weitere Personen haben diese Anleitung absolviert.
