Einleitung
This guide will show you how to clean the CPU fan on the VivoBook.
Was du brauchst
Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
Remove five 5mm screws using a Phillips 0 screwdriver.
Remove the two 2mm screws with a Phillips 000 screwdriver.
Remove the tape connected to the fan covering plate.
From the back, push the fan out of the motor.
Clean the fan using a damp cloth, and allow to dry.
