Zum Hauptinhalt wechseln
How to Clean a Canon PowerShot SD780 IS Shutter Button
Was du brauchst
  1. How to Clean a Canon PowerShot SD780 IS Shutter Button, How to Clean a Canon PowerShot SD780 IS Shutter Button: Schritt 1, Bild 1 von 1
    • Before starting, make sure to turn off the camera and remove the battery.
  2. How to Clean a Canon PowerShot SD780 IS Shutter Button: Schritt 2, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove the five outermost screws from the camera.
  3. How to Clean a Canon PowerShot SD780 IS Shutter Button: Schritt 3, Bild 1 von 1
    • Remove the front panel of the camera case to expose the top left ribbon cable. Pull the ribbon cable gently to disconnect it from the camera.
  4. How to Clean a Canon PowerShot SD780 IS Shutter Button: Schritt 4, Bild 1 von 1
    • Using a Phillips #00 screwdriver remove the single screw on the far left-hand side towards the bottom of the camera.
  5. How to Clean a Canon PowerShot SD780 IS Shutter Button: Schritt 5, Bild 1 von 1
    • Carefully pull the case apart to separate the 2 pieces.
    • The case will detach from the camera in two pieces.
  6. How to Clean a Canon PowerShot SD780 IS Shutter Button: Schritt 6, Bild 1 von 1
    • Remove the two screws on the metal plate of the camera case. This will give you access to the spring inside the metal plate for further cleaning.
    • Clean the inside of the camera with a cloth to remove dust and excess grime. This should unstick the shutter button and allow for full function.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Arlene Ale
455 Reputation
4 Anleitungen geschrieben
New Mexico State, Team 1-5, Easley Spring 2014 Mitglied von New Mexico State, Team 1-5, Easley Spring 2014
NMSU-EASLEY-S14S1G5
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 21
Insgesamt: 838
